Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 23-06-2002, 23:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
oh good... i was right. :)
Posted by Anton Abaya at 1/19/2001 10:47 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
In Reply to: Re: confuzzling gear ratio definition.. wanna clear this one up?
Posted by Jim Meyer on 1/19/2001 10:30 AM EST:
: I believe the gear ratio is the # of teeth on the driven divided by the # of teeth on the driver, or the ratio of pitch diameters, driven/driver. So if the output (wheel) is spinning slower than the input (drill motor) the gear ratio is larger than one. I would assume everyone agrees with this point. Axle ratios on RWD vehicles are always greater than one, 4.10 and 3.43 are examples for GM trucks. The place where I sometimes get confused is which is a higher gear or lower gear.
: When you downshift your car you actually get a higher gear ratio. When something is really "geared down" the gear ratio is infact really high. The lowest gear in your car is the one with the highest gear ratio. "Low Range" on pickup transfer cases and tractors produces even higher gear ratios.
: Are all of these things wrong? I don't think so. So in conclusion it depends whether you are talking about gear ratios or just gears. My robot has really low gears = My robot has a really high gear ratio. "Low Gears" seems like more of a slang term to me but I still downshift my car (5th to 4th) when I want a higher gear ratio.
: Even though I am a firm believer that there are stupid questions, I think this was a good one.
so for all you guys who cannot figure this one out...please by all means learn it.
that solves one problem, i wonder how we should gear these babies this year...hmmm
i think i'm just gonna order a whole range of sprockets and play around with all of them..
-anton
[IMG] code is Off
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
