Go to Post Practice bots are not regulated by FIRST. Your practice bot could have a flamethrower and a jamming device on it, and they wouldn't care in the slightest. You just can't compete at a competition with it. :) - AlecMataloni [more]
Go Back   Chief Delphi > Technical > CAD
Unread 26-10-2008, 23:43
jab0ii jab0ii is offline
FRC #0846
jab0ii will become famous soon enough
Truoble installing Autodesk Inventor (CAD)
Hi, I'm having trouble installing the inventor. I downloaded the 4gb file off the FIRST site from the account my mentor provided. It was in a zip file, so tried using zipgenius to install the program, but when ever it tries to finish installing, it pops up "Can't find Setup32.exe" I have no idea why it does this, or are there any alternatives that I can download this program and install it directly that's not in zip? Help me!!! thanks]
FYI: I downloaded the 64-bit version file off mozilla. Idk if this affects my install.
-Eric J.
Unread 27-10-2008, 01:15
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Truoble installing Autodesk Inventor (CAD)
There are 2 ways of downloading inventor off of the Firstbase site you can uses the Autodesk download tool or you can download 4 zip folders then merge them into one file
about the 64 version only use this if your operating system is 64 bit
-Eric J.
Unread 28-12-2008, 20:15
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
If you downloaded the zip files from the site not using autodesks tool, make sure you extract all 4 files and combine them into one bulk folder or files will be missing like crazy.
Personally, I went the lazy route and used the autodesk download tool and that worked much better.
Like Jeff said, unless you know you have Vista 64bit or XP X64, the 64 bit version will not run, it is as simple as that.
I will add that I have installed inventor 4 times, 3 times on one machine (2 reformats), and once on another.
The first time I installed it on the machine that has had it installed 3 different times, it crashed at the very end and I had to restart the installer. The other 2 times on this machine, and 1 time on the other machine it worked flawlessly, just keep in mind that Inventor (and its installer) are absolute beasts in required computing power so don't run anything else when you try to install them.
And try re downloading inventor (maybe use the autodesk tool)
Need help installing inventor seanl Inventor 8 14-01-2008 18:18
Installing inventor in personal computer Daniel_H Inventor 9 20-01-2006 23:47
Using auto cad for the autodesk inventor competition [527]phil Inventor 7 18-01-2006 10:41
Problems Installing Inventor Adam Shapiro Inventor 8 17-01-2003 22:45
