Go to Post DO NOT THROW THINGS AT THE PROGRAMMER! - demosthenes2k8 [more]
Unread 27-10-2008, 02:54
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Vex Sensors for FRC
Would these sensors work on a FRC robot?
http://www.vexrobotics.com/vex-sensors-products.shtml
R.C.
MadTown Robotics Team 1323
Unread 27-10-2008, 08:04
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Vex Sensors for FRC
The sensors on the vex page should work, but the wire has the wrong connector. All you would have to do is cut off the end on the sensor and put a different one on from a cut PWM cable or something.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 27-10-2008, 11:59
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Yeah those will work.
The only things needed to use them are:
1. different connector
2. Programmig to interpret the sensor correctly (ie: for the ultrasonic)
But, there are people who have documented using these in the past, you just need to google for the info....
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
pic: Vex-sized tubes for Mini-FRC! Jessica Boucher Extra Discussion 4 15-01-2007 19:32
VEX Limit switches for FRC Robot??? cdennisxlx2 Technical Discussion 5 18-11-2006 13:37
Loader for Vex thinks it's FRC tacman1123 Programming 2 25-08-2006 15:24
