Go to Post You're not crazy. Eleven is the new seven. - Michael Corsetto [more]
Unread 26-10-2008, 00:34
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Re: omni drive transmissions
If you are not directly driving the wheels with the gearbox output shaft, 1-2 stackerboxes and a chain reduction seems to be a very light and compact option. You could probably direct drive from a stackerbox, but I would modify them to replace the output shaft with a 1/2".
If it was $460, your robot was illegal.
I'm sorry, I misquoted the price, the actual price of a slab of that size is 200. Here is the mcmaster-carr product number for the sheet we got.
8752K518
Sorry for the confusion.
Also back on topic, we originally went with the 45° omni design in cad, but decided to go with the mecanums. Here is the inventor render of the omniwheel bot. Also, if you have access to a waterjet (or even if you don't) you can try and setup a way to get those mecanums cheaper. We contacted AM and just got the sideplates for 180 dollars, and we fabricated our own rollers from brass tubing bought off of mcmaster and sheets of rubber which we then jetted out the rollers from. It ended up saving us about 100 dollars for the set overall.
http://www.chiefdelphi.com/media/photos/29534
Also theres a bonus, a very lengthy discussion on the design for you to read through :-D
Unread 27-10-2008, 18:23
dtengineering's Avatar
AKA: Jason Brett
Originally Posted by Cuog View Post
Banebots is about as simple as it gets, however the reliability is debatable.
I think the debate on the BB transmissions has been settled... in favour of Banebots.
Comments on the BB transmission reliability comes from the initial batch of gearboxes that were shipped in the KOP two years ago. Through an effort between teams, FIRST and Banebots the reliability issue was identified as an insufficiently hardened final stage carrier plate. Banebots took responsbility for the problem and issued every FRC team replacement, properly hardened, carrier plates, and then took additional steps to toughen their gearboxes.
As far as I know, teams using the new carrier plates and/or new transmissions have had no issues with the BB transmissions.
The BB transmissions are ideal for omni-drive drivetrains as they are extremely easy to use in direct drive (as opposed to chain drive) applications. You just put the wheel on the output shaft, saving all the weight of the chain and sprockets, as well as the potential failure of having the chain come off. In my experience, the upgraded Banebots make for the most reliable drive system out there.... and we've got a mecanum drive with four of the 12:1 gearboxes on board with two regionals and several demonstrations behind them to back it up with.
Jason
Unread 27-10-2008, 19:06
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
are they a hex shaft or keyed
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 27-10-2008, 19:25
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Bane bots are keyed. we used them on our mecanum bot this last seasons with the 8" andy mark mecanum wheels. Honestly engineering the actual drive train was a piece of cake. We made a cad file of where we needed to drill holes in a sheet of 1/4" aluminum and then printed it out and drilled it in our smithy(drill press mode). The real troublesome part mecanum or holonomic drive is the programming. you need a way to keep your bot going straight. If you look on TBA our bot didnt fair well at the NASA VCU regional but we eventually got the kinks worked out in our programming and got the thing to drive reasonably straight. Dont worry so much about the calculations, those are easy, worry about programming, that is very hard and takes a long time to test. On average, teams that i have talked to take about a year to develop a good mecanum/holonomic code, so plan for this to be a rocky season
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 27-10-2008, 19:32
gorrilla's Avatar
AKA: adam spears
well we have plenty of help this year with programming including our new mentors Chas(former student now at college programming king) and Lexi(from g&t conveyors)
Adam Spears
Unread 27-10-2008, 19:57
AdamHeard's Avatar
Lead Mentor
Jason
I'll agree that the newer line is more reliable than the previous, but disagree that it is the most reliable option. I would bet the reliability of a dual stackerbox or single toughbox is substantially higher.
Unread 27-10-2008, 21:17
gorrilla's Avatar
AKA: adam spears
well i have read enough information on the bb trannies to be confident they wont break on me and that there level of reliabillity is up to par with andy mark
and seeing as how we have like 10 of them ill give them a try after i discuss it with our mentors
Adam Spears
Omni drive Laaba 80 General Forum 12 25-02-2008 01:56
Lego Omni Drive Synergy1848 Robot Showcase 19 03-01-2007 11:51
Four Wheel Drive Using Standard Transmissions daviamp Technical Discussion 4 18-01-2006 20:03
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Image Discuss: Transmissions and Drive Train CD47-Bot Extra Discussion 16 17-02-2003 22:11
