Go to Post The jags are powered with magic... - Aren Siekmeier [more]
Unread 27-10-2008, 11:39
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
2106's "lucky" at the Robot Rumble 2008
http://farm4.static.flickr.com/3054/...d1b2b3f7_b.jpg
This was the state of our robot after the first round of our finals match. Some how we snapped the support for our ball popper. One of our freshman parents is an emergency room nurse and said, " I could wrap that like a broken leg." So she did. Good thing this wasn't an official FIRST event wasn't it?
Unread 28-10-2008, 07:26
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: 2106's "lucky" at the Robot Rumble 2008
I think that the combination of DuctTape and fractures is the most common composite material in FIRST
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 28-10-2008, 19:48
sejeff's Avatar
sejeff sejeff is offline
Junior Member
AKA: Sejeff Jefferson
sejeff will become famous soon enoughsejeff will become famous soon enough
Send a message via AIM to sejeff
I think ducttape should not be allowed on FIRST robots.
Here are my reasons why.
1. It can catch fire, and release toxic gases.
2. nevermind
3. If the duct tape falls apart during a match, the attached components on the robot may fly off and hurt someone. Safety FIRST.
Unread 28-10-2008, 20:06
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Impressive fix, good enough for government work right.
2. nevermind
My problem with these reasons is that:
A. You cannot use duct tape to even cover up edges, or as we found out on our 2006 Aim High robot... use it to stick all the bristles on a brush together to help scoop in the balls.
B. We've been told you can't use duct tape to hold things on, but electrical tape is just fine and dandy. Last time I checked, electrical tape had way less abilities to adhere than duct tape.
C. Zip ties are perfectly fine for holding on key components of your robot in the rules, but I've had them just snap off randomly while components are in work. Places where duct tape would work perfectly fine.
Sorry about moving the thread off-topic more, but I think it's silly to say no duct tape period, when the intelligent use of it is perfectly fine. I'm sure there are many topics on this elsewhere, so I shall stop my rant.
Again, nice fix and congrats on making it into the finals at your event.
Unread 28-10-2008, 20:12
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
well the thing with zip ties is when they break they snap and with duct tape if its wrapped alot then it would more of rip in a couple of sections but still maintain intergrity for the most part
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 28-10-2008, 20:32
Billfred's Avatar
Billfred Billfred is offline
Moving from the "been told" to the (subject-to-change-for-2009) 2008 manual:
<R38> Adhesive backed tapes shall not be used as a structural fastener, or to connect two or
more parts together. Adhesive backed tapes may only be used as follows:
 Textured or coated tapes may be used to provide an alternate surface finish or treatment to a
portion of the ROBOT.
 Velcro tape, any hook and loop tape or double-sided sticky foam may be used for attaching
components to the ROBOT.
 Reflective tape may be used with optical sensors in small amounts.
 Adhesive backed tape and labels may be used for labeling purposes on wires, cables,
pneumatic lines, etc.
 Electrical tape may be used as an electrical insulator.
In 2007:
<R35>Adhesive backed tapes are NOT allowed except as follows:
With the exception of a different number, the 2007 rule was used verbatim in 2006 and 2005. 2007 saw many teams1 raising questions on Q&A about grip tape and related products; the official response was that "Safety Track"--which is apparently similar to the barred "grip tape"--was a legal material because it was not marketed as tape. The altered rule for 2008 eliminates that rose-by-any-other-name issue, which I view as a Good Thing. (Build season gives me enough to lose sleep over.)
1 Do a find on "tape" or "Safety Track" on http://www.usfirst.org/uploadedFiles...007-Export.pdf
Unread 28-10-2008, 23:08
wilsonmw04's Avatar
Coach
WOW, I didn't think a picture would spark such debate. Remember, FIRST is about the kids, not about the robot (or what tape is allowed or not allowed). This was an off season event and was only done after speaking with the ref and the events technical advisers.
Unread 29-10-2008, 07:12
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
The Robot Rumble has always been about giving teams a chance to play as much as possible. I've heard before that it might be too much play time.
Did everyone have a good time?
Wetzel
Viva Olancho!
Unread 29-10-2008, 07:56
wilsonmw04's Avatar
Coach
Wetzel
Absolutely. I don't think there could ever be too much play time. If only we could find more space for the pits. I hope that problem will be fixed next year when with the fair's new venue.
Uberbots 2008 Robot "Lightning" Uberbots Robot Showcase 22 24-02-2008 20:09
Video: 2106's Lucky wilsonmw04 Robot Showcase 8 19-02-2008 12:40
MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 0 03-02-2008 16:37
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
