Go to Post "there are two types of underprivileged teams; the ones who whine about being underprivileged and the ones that work to become privileged". - Undertones [more]
Unread 28-10-2008, 18:27
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
MPLAB Compile Error with MPLIB
MPLab IDE v7.20 isn't compiling the old competition code from last year's competition. It compiles the default code just fine however. MPLab C18 Toolsuite locations have been set. Any suggestions?
Make: The target "R:\2008-2009\Programming\comp\ifi_startup.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\ifi_utilities.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\main.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\user_routines.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\user_routines_fast.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\user_SerialDrv.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\user_util.o" is up to date.
Make: The target "R:\2008-2009\Programming\comp\comp.lib" is out of date.
Executing: "C:\mcc18\bin\mplib.exe" /c "comp.lib" "R:\2008-2009\Programming\comp\ifi_startup.o" "R:\2008-2009\Programming\comp\ifi_utilities.o" "R:\2008-2009\Programming\comp\main.o" "R:\2008-2009\Programming\comp\user_routines.o" "R:\2008-2009\Programming\comp\user_routines_fast.o" "R:\2008-2009\Programming\comp\user_SerialDrv.o" "R:\2008-2009\Programming\comp\user_util.o" "R:\2008-2009\Programming\comp\FRC_alltimers_8722.lib" "R:\2008-2009\Programming\comp\FRC_library_8722.lib"
MPLIB 3.90, Librarian
Copyright (c) 2004 Microchip Technology Inc.
Error - invalid object filename
Errors : 1
BUILD FAILED: Tue Oct 28 17:03:12 2008
Unread 28-10-2008, 22:56
Re: MPLAB Compile Error with MPLIB
P.S. It's your creation of the object library comp.lib with MPLIB that's failing, not any compilation.
You may not be doing what you think you're doing.
Are there multiple projects associated with last year's robot?
This isn't the normal process for compiling code to download to a robot.
How come comp.lib is referenced without the full pathname like everything else is using?
e.g.
Unread 04-11-2008, 10:31
MarkO's Avatar
MarkO MarkO is offline
AKA: Mark D. Overholser
FRC #0957 (WATSON Robotics team)
MarkO is an unknown quantity at this point
It almost looks like that MPLIB.EXE is trying to create a Library ("comp.lib")
From these Object Modules (ifi_startup.o, ifi_utilities.o, main.o, user_routines.o, user_routines_fast.o, user_SerialDrv.o, and user_util.o)
And also these Libraries (FRC_alltimers_8722.lib, FRC_library_8722.lib)
Does MPLIB.EXE let you make new Libraries from both Object Modules and old Libraries???
Code Won't Compile in MPLab with WPILib Inverted Programming 1 20-02-2007 22:12
const array - 'auto' compile error ? oddjob Programming 10 17-02-2007 01:36
compile error Chuck Merja Programming 3 17-02-2005 15:02
InterruptVectorLow error when we compile Redneck Programming 5 02-02-2005 22:57
Compile error blindguyinanorg Programming 4 12-02-2004 19:49
