Go to Post There should be no teams yelling "robot". - RoboMom [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Programming
Unread 22-10-2008, 14:27
olsmrobotics's Avatar
olsmrobotics olsmrobotics is offline
OLSM Robotics Team
None #0009 (St. Mary's Prep)
Team Role: Student
olsmrobotics is on a distinguished road
[OCCRA]: VEX Programming
We would like to address this question to Mr. Mark Center regarding VEX programming.
I have had a lot of problems with the new vex program template and have a few questions. When I try and use the template supplied on Chief Delphi, it skips autonomous mode and goes straight to user control, in addition I am wondering if I can use a while loop within the functions, or will that affect the time argument specified in the function parameters. Also,one last question, if i program a return from one of the two functions, Autonomous or User control, even though they are void functions, will it it end the function and just go back to void main, or will it crash the program.
Unread 29-10-2008, 11:25
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: [OCCRA]: VEX Programming
OLSM,
Please look at the examples I have posted in the OCCRA programming forum. Pay close attention to the example I provided for the Royal Ravens team.
You must use a while loop inside of the autonomous program, otherwise it operates just once. I found that out myself by playing with the program at home. It does not alter the time of the autonomous period (15 seconds).
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 29-10-2008, 11:38
marccenter's Avatar
Re: [OCCRA]: VEX Programming - OLSM Test Program
Dear OLSM,
Ok, Here is a sample program, same as RO ravens program with the name modified for you so Chief Delphi website would allow me to upload.
1) Autonomous operation requires you to wire a start button to input 5.
2) To activate autonomous, turn on VEX transmitter, then hit Start Switch.
3) Go to the terminal window. You should see print statements that show
the various steps through the autonomous operation.
4) A tank block has been placed in the autonomous period. Note that it does
not work with your remote controls as expected.
5) A tank block has been also placed in the operator controlled period. Note
that it does work if your motors are wired to Motor1 and Motor 2 outputs.
6) Oh yeah, my name Marc is spelled with a c not a k - for next time.
7) Don't know about what problems you will have with return statements. You will need to experiment. Place print statements in all paths to help you debug operation. Once you figure out how it works, remove the print statements, they take about 10 milliseconds each and are time intensive.
8) Go OCCRA Teams!
Marc Center
[OCCRA]: 2008 OCCRA VEX Carpet Playing Field - Home Depot marccenter OCCRA Programming 1 06-11-2008 09:57
[OCCRA]: OOCRA 2008 VEX Programming Workshop marccenter OCCRA Programming 0 14-09-2008 20:17
[OCCRA]: vex programming HPRobotics OCCRA Q&A 1 02-10-2007 21:43
[OCCRA]: VEX Programming kit Eric Yahrmatter OCCRA Q&A 1 16-09-2006 10:52
