Go to Post “Chasing perfection is like trying to find a unicorn. If you go all around the world, you will not find a unicorn. However, you will find a whole freak load of stuff along the way.” - Karthik - Jacob Bendicksen [more]
Unread 29-10-2008, 15:08
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
pic: FRC488 - 80/20 Drive Train
Unread 29-10-2008, 15:10
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Re: pic: FRC488 - 80/20 Drive Train
Looks solid. Do you have an estimate of what it wieghs in it's current design state? Also the question I really have is are you using two servos to shift the dewalts, if so have you done any testing with it?
Unread 29-10-2008, 15:13
Madison's Avatar
FRC #0488 (Xbot)
It's 22.25 lbs. as shown. It's missing chains, obviously, and some brackets and fasteners required for mounting the gearboxes. It'll probably hit 28-30 lbs. with those things and with an ABS base for control system components.
We had some trouble shifting the DeWalt gearboxes with a single servo last season, so we've been thinking about adding the second to each. We haven't tried it yet.
--Madison--
...down at the Ozdust!
Unread 29-10-2008, 15:18
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How are the bearing blocks held in place on the 80-20? Other then that it looks like s very good simple drivetrain. I guess you didn't see a need for the second set of cims last season?
Mentor 2415
Unread 29-10-2008, 15:20
Madison's Avatar
FRC #0488 (Xbot)
The bearing blocks are 80/20 pivot pieces. We're going to open the pivot hole from 1/4" to 1/2". They tie in to the 80/20 from the top using their existing mounting holes. They're part no. 4181.
We had some trouble shifting the Dewalts and made no use of 3rd gear last year, so we were a bit slower than I'd hoped. As always, the game may change what we put into the drive, but if we can avoid pushing matches again, we'll probably stick with 1 CIM per side. Similarly, it's shown with four traction wheels, but we may again use just two and put omniwheels back onto the corners.
We expect to have our hands full with the new cRio system, so anywhere else that we can remove complexity, we'll do it.
--Madison--
Unread 29-10-2008, 16:27
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
I would never mount bearing blocks to 80/20 using the T-slots. They slip way to easy under the strain that is being placed on them. Drill through the 80/20 and bolt them right into it.
Thats just my opinion.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 29-10-2008, 16:30
Madison's Avatar
FRC #0488 (Xbot)
Well, the simplicity of this design is that 80/20's slot system substitutes for chain tensioning mechanisms. If we were to eliminate that advantage, we'd change the design entirely.
We haven't used 80/20 much, but have had success with it staying where we put it as long as the bolts are properly tightened.
--Madison--
Unread 29-10-2008, 16:36
Lowfategg's Avatar
AKA: Tyler Moser
Well I guess then the T-slots are nice to have for that, but make sure to keep up with those screws. My experiences with 80/20 last year were not that great, but some people like it.
Unread 29-10-2008, 16:38
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Madison, this looks like a very simple, easy to put together design.
The only weaknesses are, in my eyes, angular clearance for ramps.
Assuming the wheels are centered at 3/4" above the 8020, and positioned about 3.5" back from the inside of the front rail, that only gives you about 17 degrees of angular clearance. But for a flat-field application, this looks like a very nice drive that you could easily modify at any point.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 29-10-2008, 17:00
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
You are right, as the t-slots do allow for the t-slot nuts to slip. However, another thing to do besides drilling a hole is to just add another t-slot nut to back up the initial nut. If there are 2 in a row, and both are tightened well (and checked routinely), then the slippage does not happen.
Andy
Unread 29-10-2008, 17:02
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Why do you need a six wheel robot if you are using omni's? also watch out, 8020 bots get heavy, fast. on our 2006 robot we essentially built our entire robot out of 8020. There is alot of un necessary weight in 8020. Do you really need all for slots in the metal? it is very strong and is very fast, so if your going for a fast build this is what you want. Also, what size 8020 are you using, the inch or half inch?
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 29-10-2008, 17:05
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
8020 itself is not actually particularly heavy. A very long time ago I did the math to see for myself and the 1010 series is almost exactly the same weight as 1x1x0.125" Al tube. The weight difference comes from all the connectors, t-nuts, and fasteners.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-10-2008, 17:24
Madison's Avatar
FRC #0488 (Xbot)
Yeah, this can clear a 17* angle, but nothing greater. If there's anything steeper, we'll figure out how to deal with it as a special circumstance -- or we'll turn the chassis upside down.
6WD does a bit better at getting over obstacles -- whether those be field elements or game pieces. Again, the simplicity here is that we can swap in any sort of wheels we'd like easily -- and we can add or remove "drop" as necessary.
The profile shown is 1010 -- 1" square.
We have a good history of building reliable drive trains that are also very light. We've been working lately on minimizing manufacturing time, so we're conceding some of the features that make things light in favor of those that make them quick to build.
Andy
That'll be Fred's job. Fred is the advocate for 80/20 on our team and even then we use it sparingly. If it breaks, it's his fault.
--Madison--
Unread 29-10-2008, 19:12
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Our base was almost exactly like this last year and we had a few problems because the middle wheel was more dragging than helping
We removed it for Cal Games this year and it made a noticeable change when driving, but other changes we made to the robot made it hard to actually compare.
Unread 29-10-2008, 19:32
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Great design, you could build that whole thing in a day! Well, except for the transmissions... I like how you completely eliminated the need for any tensioning device with the use of 80/20, very clever. The only "problem" I can see with it is the lack of any diagonal bracing, but I suspect the electronics board or the top half of the robot will account for that. I doubt that you'd let anything like that slip by.
pic: FRC488 Completed Drive Train Madison Technical Discussion 18 26-01-2008 12:57
FRC488 Drive Train Video Madison Robot Showcase 9 21-01-2008 13:20
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
