Go to Post It truly is a Merry Vexmas! - Ginger Power [more]
Unread 20-10-2008, 10:52
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
[FTC]: Trivial things that can cause big problems.
During our first few days of really trying to build stuff with the FTC Tetrix hardware, I couldn't figure out why the kids seemed to be able to break, or jam the various HEX drivers I had purchased for the team.
Finally I figured it out...
The Tetrix kit includes a neat little fastner for attaching an axle to most plate parts. It has a slot and machine screw used to compress the slot and clamp down on the axle.
The key technique that seemed to be lost on most of the kids was that it's important to insert the machine screw into the part from the correct side.
If you look at the hole that bridges the slot, one half is threaded, the other is not. The idea is that you insert the screw through the larger non-threaded hole, and then screw it into the threaded side. Now if you tighten the screw, it clamps the piece down on the axle.
However, if you insert it in the other way, it serves no function at all, except as a really frustrating exercise for the kid, who, no matter how hard he tightens the screw, cannot get it to grip the axle tightly....
Hence the collection of broken tools and screws that need to be forcable removed from the piece.
So.... if you haven't already, I suggest you add this to your next "training" session with your kids.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 20-10-2008, 18:10
ttldomination's Avatar
Sunny
Re: [FTC]: Trivial things that can cause big problems.
I have yet to receive my kit, but when we do, i'll be sure to look over that.
1648: 2013-2014
5283: 2015
Unread 20-10-2008, 20:37
Abra Cadabra IV's Avatar
Abra Cadabra IV Abra Cadabra IV is offline
Still spinning in circles
AKA: Katy W.
FRC #2429 (Blockheads), FTC #25 (Rock-n-Roll Robots)
Abra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really nice
Already found that out the hard way. Nothing was damaged too much, but it was a really frustrating way to waste half an hour trying to figure out the problem.
Thanks for posting this. It should save some other teams the frustration.
Proud alumna of:
FRC Team 2429 - Blockheads
and
FTC Team 25 - Rock 'n' Roll Robots
Unread 20-10-2008, 21:39
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
I broke and bent a few myself before noticing the error in my way. I can't believe I actually read the manual they gave us, although it could really use some additions to it.
BTW, when you get to mounting servos with gearing, don't waste your time trying to find the correct standoffs, its much easier to drill the holes out that get 1" standoffs, sand them down by an 1/8", put spacers to offset the servo, and then finally mount them, just drill four holes and you will feel much better after and save yourself a lot of time
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 20-10-2008, 23:31
PhilBot's Avatar
AKA: Phil Malone
I wouldn't mind seeing a picture of that....
Phil Malone
Unread 24-10-2008, 23:16
gdo's Avatar
gdo gdo is offline
AKA: Patrick
Has anyone done servos with gearing so far? Maybe I was missing something in the way to mount them, but as soon as I tried to gear the servos for a 2:1, the spacing would not work from whatever I saw. Maybe we are just supposed to do 1:1, but I don't think my design will life all the pucks I wants to with 1:1.
Unread 25-10-2008, 22:06
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Back in March; using the Small (S), Medium (M) and Large (L) gears we were given for the Showcase, it was relatively easy to create any of the 1:1 gearings and to create the S:L gearing. However, I too had fits trying to assemble a S:M or M:L gear train. The big holes were not in the right spots to make it easy to create those ratios. So - You and I appear to be equally clever
I remember kludging something together back then but I didn't take pictures.
Bottom line: I think that the S:M and M:L gear trains can be built; but I don't thenk the result will be as elegant as the 1:1 and S:L gear trains. Maybe someone else has figured out a good way to build them?
Blake
Unread 29-10-2008, 20:22
Sunny
Hm...we seem to be having trouble with the clamps for the axles as well, the axles seems right, but then it continues to slide around. I'll go back and check to make sure it's in right.
Thankx.
1648: 2013-2014
5283: 2015
Unread 30-10-2008, 11:12
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
I have been telling the kids not to put in all four screws before clamping to the axle. I only recommend using three so one side of the clamp will still move.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 30-10-2008, 16:20
Sunny
Right now we are only using two. We are running low on screws and we will be placing an order soon. When we get our roughly 300 screws in, I expect we'll put more in. .
Does anyone know where to order the large screws? Like the really long ones?
1648: 2013-2014
5283: 2015
Unread 30-10-2008, 17:13
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
i believe you can get them from mcmasters. they have almost all the nuts and bolts you will need, and in a higher quality metal.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 31-10-2008, 09:09
Sunny
Are they legal? Are we allowed to purchase them?
1648: 2013-2014
5283: 2015
Unread 31-10-2008, 09:42
VRC Coach
AKA: Jon T
If they are identical they are legal. So they need to be the same type,size and finish. I plan to order some.
Does any one know the length of the longer screws?
Jon Thompson
Coach
NASA Knights
Unread 31-10-2008, 20:03
Sunny
They should be in the little manual. I think they're 1.25" but make sure you check. Could you post the link here after you've ordered them?
1648: 2013-2014
5283: 2015
Unread 12-11-2008, 08:58
VRC Coach
AKA: Jon T
Here are the longer screws I ordered from
http://www.mcmaster.com/
http://www.mcmaster.com/nav/enter.asp?partnum=90128A164
http://www.mcmaster.com/nav/enter.asp?partnum=90128A160
They look identical to me.
Jon Thompson
Coach
NASA Knights
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
Things that are unnecessary wolfj Chit-Chat 40 06-04-2008 14:28
Victor failure question--Can power from motors cause them? Kit Gerhart Electrical 6 13-12-2007 17:56
Things that new members need to know about electronics Karma Electrical 10 20-11-2006 08:35
A Small Favor for a Big Cause ComBBAT_Amy General Forum 6 30-03-2003 12:26
