Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
  #31   Spotlight this post!
Unread 27-10-2008, 14:40
Joining the 900 Meme Team
FRC #0079
Re: Mistakes
Originally Posted by Enigma's puzzle View Post
we had a couple of small metal shavings fall into the victor, it didnt move very far when we put the robot on the field.
We had this happen a couple times at RUSH, after spending 3 hrs trying to figure out what the error was (this is why you should always consult the manual FIRST kids) I had a nice long chat with one of the mechanical mentors about how he is never to drill without covering the brain again. I just reminded him that if he did it again we might not be so lucky and something could of been damaged.
The programing team also forgot to put an absoute value into the mecanum programing, That robot only went left, and later we decided to name it lefty
Always the fault of the programming team eh?
  #32   Spotlight this post!
Unread 27-10-2008, 18:30
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Wink Re: Mistakes
Always shave down the metal AWAY from the RC!!! And then we learned that its not always the programmers fault...
Also, 2 days ago at Cage Match in Indianapolis. Make sure you use a insulated tool when working on batteries. It turns out that the negative side which was taped up had been pulled out slightly, and i did not see the revealed wire. So the all metal multitool that i was using made contact with both polarities and sparks flew. Then i pulled the tool away from the battery. Only then did i realize how hot the tool had become. Now it has burn marks on the tool i was holding, and i could not feel my fingers while driving in the elimination round. In order to remind me, i think i may make shirts that say "Samir, don't electrocute yourself" with a pic of a body getting hit by a lightning bolt inside one of those red circles with a slash down the middle.
  #33   Spotlight this post!
Unread 28-10-2008, 00:18
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Re: Mistakes
I guess anyone at Silicon Valley in 2006 may remember this- our robot was doing really well, got picked by the Cheesy Poofs, and then in one after-lunch match, one of our wires connected with the battery and our robot literally burst into flame. Already one person on our team was running to the robot with a fire extinguisher, but luckily fire went out before extinguisher was necessary. Phlebas the Informer/Transformer was nicknamed Smoky Bear (our team name is M-A Bears, nicknamed Ma Bears in 2006).
Lesson- always recheck wires before quarters, semis or finals, because that's when Murphy's law really kicks into gear.
Oh yea, speaking of Murphy's Law, there was a time a mistake qualified as Epic Fail. Also in 2006, we were doing well at Cal Games when during the semis, every single ball bearing broke at the same time. We only found out when our robot began leaking little steel balls everywhere... and couldn't move.
Lesson- make sure your sizes are right! The whole season, summer and qualifying matches the spacers on the bearings were too big and ground into the bearings every time we moved. The final crash was just too much for said bearings.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
  #34   Spotlight this post!
Unread 30-10-2008, 01:35
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Re: Mistakes
Murphy's law always kicks in at the worst times doesn't it?
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
  #35   Spotlight this post!
Unread 30-10-2008, 13:20
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Mistakes
IRI was a real bummer this year. You guys broke your front forks, got it fixed in a miraculous 5 minute period, only to go out and find that a PWM cable had come loose. This past year was one of your best robots ever, and its a shame that it had to go out like that.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
  #36   Spotlight this post!
Unread 30-10-2008, 14:29
FRC #0079
Re: Mistakes
I'll pass on the compliments, I don't work with RUSH that much anymore. You know that whole thing where the kick you out of high school for having accumulated too many credits? Yeah had that happen after the 2007 season. Let me tell you though, having the team I work with now (397) partner with RUSH at Kettering was possibly the highlight of my years in FIRST.
Story time from 397 now though, we were testing autons. In every auton the feather raises right at the start, well, we got tired of putting it back down manually so we pulled the power to it. The mistake? We never plugged it back in. And as anyone who has seen our machine can tell you, if the feather doesnt come up our entire machine is useless because the forks cant deploy. Which meant we were pretty well screwed that match.
  #37   Spotlight this post!
Unread 30-10-2008, 15:44
clark_noah's Avatar
clark_noah clark_noah is offline
FRC #1245
clark_noah has a spectacular aura aboutclark_noah has a spectacular aura aboutclark_noah has a spectacular aura about
Re: Mistakes
a few years ago at the Denver regional (rack and roll challenge) we made semi finals but our chain keept poping off, and we had no idea why. Our robot couldn't compete, and we may have won the regional if this had not have happened.... later, after the competition, we found a very very small 20 gauge (maybe) wire stuck in the gear box that was causing our gearbox to screw up and dechain our robot. (i don't even know how....?) It sucked..... :[
we learned that it was all electricals fault and that those jerks should keep their wires organized! lol. jk. the whole team learned the importance of being organized...
the sad part is that we still are not organized.
  #38   Spotlight this post!
Unread 30-10-2008, 19:07
Re: Mistakes
Oh yeah, thats probably one of the most important parts of being in electrical, keeping it all organized and understandable.
That's why this year I'm laying schematics before we start.
  #39   Spotlight this post!
Unread 30-10-2008, 23:15
clark_noah's Avatar
FRC #1245
Re: Mistakes
ya, seriously, you electrical people need to keep all your junk from the moving parts, i'm so sick of stuff like that happening!
lol. just kidding. XD
every year we make a schematic and it looks nice, but then we keep adding wires, we forget something, like a sensor that we added at the last minute (which never did end up wordking. lol) or something...
  #40   Spotlight this post!
Unread 31-10-2008, 00:08
Arthur S's Avatar
Arthur S Arthur S is offline
FRC #0004 (Element)
Arthur S is on a distinguished road
Send a message via AIM to Arthur S
Re: Mistakes
Our lead electronics head last year was playing around with one of the circuit boards and somehow bridged two wires together and like the wires went crazy red and then melted like half of the board. No really bad injuries thank goodness, just a little cut on the finger.
all models are wrong, but some are useful.
-George E. P. Box
  #41   Spotlight this post!
Unread 31-10-2008, 00:40
Re: Mistakes
and that's why we have fuses.
  #42   Spotlight this post!
Unread 02-11-2008, 01:43
clark_noah's Avatar
FRC #1245
Re: Mistakes
fuses..... why I hardly know the meaning of that word. lol. you mean a piece of tin foil crumpled up????
lol.
  #43   Spotlight this post!
Unread 02-11-2008, 12:53
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Re: Mistakes
lol.
No pennies, they fit nicely in the 40A fuse block.
A2D Solving the Imaginary Error Function...
  #44   Spotlight this post!
Unread 02-11-2008, 16:11
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: Mistakes
mistakes- how about your Robocoach making a perfect run and knocking down both track balls - and then suddenly realizing we are the OTHER color?
oops!!
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
  #45   Spotlight this post!
Unread 02-11-2008, 16:20
clark_noah's Avatar
FRC #1245
Re: Mistakes
really? awesome!
although with resetting fuses, they never go bad and there is no need for pennies.... lol
thats not a mistake, its called Gracious Professionalism.
ok, maybe it is a mistake. I just wanted to use my vocabulary. lol
Stupidest Programming Mistakes Matt Krass Programming 61 08-08-2006 14:26
simple mistakes birdman Rules/Strategy 8 10-04-2005 23:32
Top 5 mistakes Rhs953 Chit-Chat 12 22-02-2004 20:33
Mistakes J2Kraatz General Forum 11 23-03-2003 20:47
