Go to Post I fear not the drive team who has practiced 10,000 defenses once, but I fear the drive team who has practiced one defense 10,000 times. -Bruce Lee - bEdhEd [more]
Unread 30-10-2008, 15:53
NetSkay NetSkay is offline
FRC #1793
NetSkay is an unknown quantity at this point
uploading source onto cRIO?!
im not new to programming, but im new to robotics programming... so in my guess its a matter of learning the technique, not the syntax and structure...
this year i know there will be major changes, aka the cRIO controller, what leaves me in the shadow is that, say i use any IDE i want, or the supplied IDE, how will i upload the compiled code to the cRIO, i know for the previous controllers a IFI_Loader application tool was used to transmit the data over serial port, but what about this year?!
i guess the CDs that FIRST ships will have both graphic adn text based programming options, hopefully...
but we're left speculating, atleast thats my impression so far
yea yea yea i know there is labview, but this is not programming, this is, i cant even name it, turning a FRC into a lego mindstorm kit, no thnx... and since im the only programmer ill take the advatage of a text-based programming...
thank you
Unread 30-10-2008, 17:23
Re: uploading source onto cRIO?!
From what I understand, downloading to the robot currently involves FTPing your compiled code to it. That may change to add some security, but it shouldn't change too much.
Unread 30-10-2008, 17:26
FRC #1793
and they'll ship libraries and such with the CDs that come with the controller for textual C++ programming, atleast thats what FIRST has done in the past, right?!
Unread 30-10-2008, 19:01
Roboj Roboj is offline
no team (National Instruments)
Roboj is an unknown quantity at this point
The beta teams have the controllers and are working with both environments. They are anxious to answer all of the questions you have so I'd suggest starting here:
http://forums.usfirst.org/forumdisplay.php?f=743
You will get both programming environments. They both have full download utilities to get your code onto the robot and it doesn't require FTP unless you want to do it that way. The IDEs themselves have a "run" button inside them that will compile your code, automatically download it over wireless, and start it going.
Unread 19-11-2008, 08:59
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
There are two ways to download into the cRio. Both of them seem to require you to plug your computer into the operator's console Using an ethiernet connector. When you are debugging, there are some setup options in Workbench that tells workbench where your cRio is on the network. You will be assigned an IP address for your controller. example: 10.1.38.2 for team 138. Once this is set up, the downloading is done from Workbench with a single button push.
That down loads your program into RAM. YOUR PROGRAM WILL BE LOST IF YOU POWER DOWN THE CRIO.
The second method is for competition. The cRio has a 150 Meg flash drive built in. There is a magic filename that is automatically booted when the cRio powers up. There is a menu item that "Deploys" your program. What that does is basically ftp your program to that magic file. If you don't do this, your robot will just sit there when you power up.
I don't know if the debugger works with a "deployed" program. If it does, than teams should just always deploy. If it doesn't allow debugging with a deployed program, than teams will have to develop some discipline like checking that the robots boots before going out to the playing field.
Unread 13-01-2012, 19:41
leeboy1312 leeboy1312 is offline
FRC #4021
leeboy1312 is an unknown quantity at this point
I am uploading the program through netbeans and it is saying there is any error build.xml:96 and at upgrade.xml:40 what should i do?
Uploading Old Code G1279 Programming 1 12-01-2008 22:35
Loading Code Onto 2005 RC chris31 Programming 13 08-11-2006 07:45
how to mount a lcd display onto a robot mechanicalbrain Electrical 9 07-09-2005 20:57
Problems Uploading to Streamline Scott Ritchie 3D Animation and Competition 24 28-02-2005 00:46
sketching onto revolved surface ajlapp Inventor 3 05-01-2005 23:14
