Re: [FTC]: parts that should have been made??
I think that ...
1. Omni-Wheels would've been a good idea. 2. If we did have sliding metal, we wouldn't be allowed to use it. It's a challenge that FIRST presents. Notice in the rules, when VEX metal is mentioned, the linear slider pack is singled out and excluded. |
i did notice in the rules that the linear slide from vex wasnt allowed but i still think it would have been a nice addition.
you can make items with the Al and the Polycarb. Don't worry too much about what didn't come in the kit. Worry about what you can do with the parts in the kit.
The biggest weakness we've found so far is the split clamps. We have these monster gears and motors and no good way to tranfer the torque to the axles. It is very frustrating.
I think that the clamps are wierd, there should be longer exles, and there should be a way to to make sure that we don't have to rely on Lego parts if we are going to use the LEGO motors. The Lego gears and Tetrix gears don't even go together.
Three words... "Continuous Rotation Servos"
I miss them so ![]() |
#7
that would be motors. . I think that the tetrix kit should have weaker motors we could use. Just so that we're not vamping up on Drive motors. But I think the Lego motors are to...different than the tetrix to be *easily* adapted into the kit. |
#8
i wish there was some treads so that we could use that again like last year
#9
Omni wheels in two or three sizes.
Small sprockets and chain, with a reliable interface to a small-ish motor (Lego or a continuous-rotation servo). Plastic chain would be fine here. Medium sprockets and chain, either metal or plastic. Suitable for drive trains. Linear motion devices (either simple like Vex, or a commercial drawer slide) Pneumatics More gear sizes Plastic gears (those aluminum gears are $$$ and over kill for a lot of uses) More aluminum structure choices -- shallower c-channel, flat plates, angle Drill the star-pattern on every axle-sized hole in the metal. It's inconvenient not to be able to mount stuff wherever you want without a drill. Tank treads. Vex got this exactly right -- they are useful for a lot more than just replacing wheels. We need a better mechanical servo interface. The bracket is too difficult to assemble and disassemble. Something to transfer power that is lighter and longer than the current axles. The square Vex axles are great for this (and fit right into the Lego motors, too). The plastic bearing blocks, lock collars and square axles from Vex are a good model. There's a lot to like about the current kit, but it shows that it's a version 1.0. Keep the good stuff coming. |
| Simple things that have made your life better or easier | KenWittlief | Chit-Chat | 15 | 25-10-2005 06:16 |
| pic: Segways have been around longer that we've thought! | Erin Rapacki | Extra Discussion | 7 | 25-09-2005 21:56 |
| Should all three pneumatics pistons have been received? | Jordan A. | General Forum | 6 | 08-01-2002 13:48 |
| Should the stretcher have been used more? | Tom Fairchild | General Forum | 8 | 26-08-2001 02:40 |
