Re: Bridge Pressure????
Posted by Raul at 1/21/2001 6:25 PM EST
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola. In Reply to: Re: Bridge Pressure???? Posted by Dodd Stacy on 1/20/2001 5:56 PM EST: OK, so if the 10lbf is correct then the bridge weighs roughly 174 lbs. Using a simple static force model: F = Wx/l F = force to lift or lower from horizontal W = weight of bridge structure x = distance from bridge CG to edge of fulcrum l - distance from edge of fulcrum to end of bridge So, at start, x is half of fulcrum width which I assume is 5.875" (5.635 lumber + 2x .125 angle iron) which makes x = 2.9375". The distance 'l' depends on whether you are lifting or lowering the bridge. Notice that 'l' is greater for lifting, so that force should be just slightly lower - we'll ignore that for this rough calculation. Use the average length of 51" since Dodd gave us a rough force of 10lbs in both directions. So W = Fl/x = 10x51/2.9375 = roughly 174 lbs Raul : Roughly 10 lbf to push up or down from the horizontal balance point, roughly 1 or 2 lbf to move it from the tipped positions. |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 24-06-2002 03:13 |
| pressure sensors | archiver | 2001 | 0 | 24-06-2002 02:15 |
| Team 111 Picture | archiver | 2001 | 18 | 24-06-2002 00:50 |
| Need help with 255 Variable | Joseph F | Programming | 18 | 26-02-2002 14:49 |
| Using Base 36 "Compression" For Easier Scouting and Other Interesting Tidbits | Adrian Wong | Rules/Strategy | 9 | 21-09-2001 20:28 |
