[FTC]: Lego Axle Question
Hello Everyone.
I have a quick question. I am wondering how long the longest Lego Axle in the kit is? I'm trying to look online but apparently "stud" is now a unit. Also, does anyone know a way to switch from lego pieces to Tetrix/VEX pieces? Cause it seems to me that if you want to use the LEGO motors, you have to use the Lego parts... Thankx. |
Re: [FTC]: Lego Axle Question
LEGO standard units are "studs". One stud is the length of the top of a 1x1 piece. Or, a 4x1 piece is 4 studs long. I'm sure you can measure one of those in inches.
A LEGO stud is approximately 5/16" wide, or 8mm. I believe the longest solid axles that come in the kit are 12 studs long, or 3.75". LEGO makes a lot of other wierd pieces, though, that aren't in usual kits. I have a 32 stud long axle (10"), which is the longest I know of. You can buy them online at bricklink.com, but I don't know the rules on LEGO pieces for FTC.
I don't think we can use the 10" axles, considering they didn't come in the kit, but i figured out that there must be some extenders in the kit so i guess it'll be alright.
| [FTC]: Conveyor Belt Lego Parts | Shimoniskey | FIRST Tech Challenge | 7 | 18-11-2008 19:58 |
| [FTC]: FTC Ramp Question | fbaldi25 | FIRST Tech Challenge | 5 | 14-10-2008 16:13 |
| [FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) | Mr. Lim | FIRST Tech Challenge | 2 | 03-03-2008 11:54 |
| [FTC]: [FTC]: Ontario Provincial FTC Start/End Times | cbhl | FIRST Tech Challenge | 8 | 16-12-2007 13:37 |
| Lego RCX Polarity Question | SteveO | Lego Mindstorm Discussion | 1 | 08-02-2006 02:31 |
