Go to Post By seeing other robot designs, teams can plan before hand on how to defend or defeat it. - Don Wright [more]
Unread 05-11-2008, 14:20
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
3 speed trany on the cheap
link
Sturmey Archer's S3X fixed-wheel three-speed hub will be available in January, Sturmey's US marketing manager told BikeRadar at Interbike today. Retail price for the hub is expected to be in the US$140-160 range.
The S3X will probably come with a multi-location shifter that can be used as a bar end or mounted on the down tube. Unfortunately, said Prosser, it's not possible to make it work with current brake/shift levers, so drop-in compatibility with, say, Shimano STI units, won't happen.
"Prosser said that the final production version of the hub will be lighter than the current prototype. It's hard to see where you save weight in a hub gear as there's an unavoidable amount of metal needed in the internals, and it's not like possible buyers of a three-speed fixie hub can go buy someone else's lighter alternative.
Or can they? We haven't seen it yet, but SRAM apparently has a hub that can be switched between fixed-wheel and freewheel operation and is rumoured to be working on its own three-speed fixed hub.
Prosser explained some of the background to the S3X project, which was basically by a steady stream of inquiries to Sturmey from various places around the ‘net (including, this writer, who stopped bothering Prosser about it when he told me that to resurrect the old ASC hub, Sturmey would need an order of 10,000 units.)
Various people, including the late great Sheldon Brown, helped gauge the level of interest, and Prosser hinted that if the S3X is successful, then Sturmey will consider widening the range with, for example, a closer-ratio version akin to the original ASC."-from http://www.cyclingnews.com
this came up on the unicyclist forums i know some teams talked about useing this kind of hub but it was going to be really hard to get them not to freewheel but this one are made for fixed gear bikes one thing to think about is that you would prol want to back drive them (ie motor powering the outside hub and the out put being the "input" collar) so you so you would not be gear up the output
cool but 340 and 424 will stick will AMs
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 05-11-2008, 14:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 3 speed trany on the cheap
Originally Posted by colin340 View Post
link
this came up on the unicyclist forums i know some team talk about use this kind of hubs but it was going to be really had to get them not to free wheel but this one are made for fixed gear bike were you do not have the free wheel one thing to think about is that you would prol want to back drive them ie motor powering the outside hub and the out put being the "input" collar
The ratios range only from .77:1 to 1.33:1, so they're probably not varied enough for most FRC applications.
--Madison--
...down at the Ozdust!
Unread 05-11-2008, 16:29
Dick Linn's Avatar
no team (Synergy)
Unless the specs on the hub have changed:
The hub will be made using a much stronger aluminum hub shell. Overall gear range will be 160%.
* 1st Gear -37.5%
* 2nd Gear - -25%
* 3rd Gear - Direct Drive
* Gear step gear 1 to gear 2: 20%
* Gear step gear two to gear 3: 33%
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 05-11-2008, 17:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Interesting hub....I ride a really old Schwinn with a normal 3 speed AW hub, and my kids ride fixies and unicycles.
Thanks for sneaking it in here
Unread 06-11-2008, 08:14
Dick Linn's Avatar
no team (Synergy)
I looked into these quite a while back. As Madison says, the range of ratios is fairly narrow.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Cheap Speed Controllers neutrino15 Electrical 7 12-05-2008 14:59
Omni on the cheap. sanddrag Technical Discussion 1 26-05-2005 20:54
