Go to Post They're pigs, Barry, pigs. And they can fly... - JaneYoung [more]
Unread 05-11-2008, 16:36
NextPerception NextPerception is offline
Sleep-Deprived
AKA: Matt
FRC #0437 (Richardson Robotics)
NextPerception has a spectacular aura aboutNextPerception has a spectacular aura aboutNextPerception has a spectacular aura about
Send a message via AIM to NextPerception
Question Motor that can be dropped off a building.
Has anyone ever run across a motor that is about the same size as the banebots 28mm 20:1 gearmotor that can basically be dropped off of a cliff and still work? I have been looking around at Maxon, MicroMo, and a couple others but I havn't found anything that seems extraordinarily satifying.
I need a gearmotor that can fit in a 1.25"(32mm) space and can't be longer than 2.9" (72mm) not including the shaft. Price isn't really an issue for this project either. Im going to be running this rig on 16.5 volts (the new A123 Lithium cells are amazing by the way) so I'll probably be overvolting a 12 volt motor.
I just really don't trust those banebot transmissions anymore.
Thanks
What is this S - L - E - E - P you speak of?
Battlebots - My Robotics Website
Hey, Where Can I Get That Animation From The Kick-off? DaBruteForceGuy General Forum 20 05-01-2008 22:50
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Fixing the drill motor you dropped part 2 Jim Harbison Motors 2 24-01-2003 12:34
Fixing the drill motor you dropped Jim Harbison Motors 0 18-01-2003 16:14
building materials, can we use....... archiver 2000 2 24-06-2002 00:11
