Go to Post I guess my only option is to either stop picking on Dave or come up with an even better picture! Now, which one do you think I'll choose? - MissInformation [more]
Unread 05-11-2008, 16:46
boehmz boehmz is offline
FRC #1730
boehmz is on a distinguished road
Physique Modifier
We made a 3D character using cylinders, spheres, and other simple shapes. Each object is a different object. I tried to apply the physique modifier, but it will not let me. Do I need to do something to the objects to make them able to be used with the physique modifier? I tried selecting them all and converting them to a mesh. Then I tried grouping them, but it does not work.
Unread 05-11-2008, 18:02
lilwupster lilwupster is offline
AKA: Brett Van Dorn
FRC #0303
Team Role: Animator
lilwupster has a spectacular aura aboutlilwupster has a spectacular aura aboutlilwupster has a spectacular aura about
Re: Physique Modifier
you should be able to apply the modifier on any geometry. Is it that you can't apply it or you are having a problem with it after it's on?
just a note, if you have not attached your objects together, make sure you apply physique separately to each object and don't just highlight them all and apply it.
BVD
Unread 11-11-2008, 16:17
FRC #1730
Ok I got it working now, and most of the objects are smooth when I turn them. The only thing, I now realize my character model may be a little too complex. It has 47000 polygons. Is there any quick way to decrease the number of polys, as I am experiencing some slowdown just working with the character.
Unread 11-11-2008, 19:32
AKA: Brett Van Dorn
FRC #0303
Team Role: Animator
you can try the optimize modifier, but it probably won't do you too much good.
To work with the model, you can either hide the polygon and just work with the bones until you're ready to render, then unhide and render.
Or you could go into the polygon's properties and select 'display as box' and still just work with the bones. It will still render, but you will not see it in the viewport making the environment easier to work in.
BVD
Unread 12-11-2008, 13:14
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Here what I do, 47000 is nothing for a character. Rig the character with bones. Then apply edit poly modifier to the bones and then shape the bones to a low poly representation of your character. Then hide the mesh of your character. You can animate in real time and you can still see the volume of your character. Then, right before you render, unhide the mesh that is skined to the bones.
I wouldn't recommend using fins on the bones. They just get in the way and tell your nothing about where you character is.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Stupid Flex Modifier *Kicks it* Walkin Stummik 3D Animation and Competition 5 11-02-2006 12:51
