Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Unread 05-11-2008, 17:46
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Alternative Materials
for our ramps in 2007 we used thin sheet aluminum backed with foam.
recently we have been using gatorboard (corrugated plastic) in our robots for electronics boards
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 05-11-2008, 17:56
In 2007, 330 used corrugated plastic and thinwall aluminum tubing for their ramps. Their robot also featured a fiberglass arm. In previous years, they've experimented with fiberglass, thinwall, and nylon.
Also, there is that tubular plastic that any home improvement store carries: PVC. It's great for arms, rollers, and light-duty protection.
Unread 05-11-2008, 20:21
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Well this year, we started with aluminum arms. In Trenton, all 3 sets we made got completely destroyed. We needed an alternative, and we thought titanium. So we made titanium ones that worked 10 times better.
Unread 05-11-2008, 23:28
dtengineering's Avatar
AKA: Jason Brett
And, I meant to add, if you are looking for inspriation for what can be done with wood (above and beyond the Mosquito, that is) check out http://www.joeharmondesign.com/ for a wooden car.
Not just any car... a 300mph exotic... that almost fits the new "no metal" rule. Wooden springs, spokes, supension... wow!
Jason
Unread 06-11-2008, 23:06
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
lexan/polycarbonate
You can get the stuff in this green house building stuff. It's ribbed and is incredibly light. 525 will attest to this, they used it on their arm last year. Crazy stuff.
-Vivek
"we don't build robots, we build people"
Unread 10-11-2008, 01:08
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
One of my favorite materials of all time for small parts is Acetal resin (Delrin). It is a good bushing/spacer material and some teams have even used it for gearbox plates.
Polycarbonate has reached the point of almost being mainstream, so I won't go into detail. However, keep in mind that it comes in tubing as well as sheets.
One of MORT's cooler innovations has been polyurethane foam. It's a two-part mixture (like an epoxy) that expands to fill whatever you pour it into. It's good for adding rigidity to tubes.
Also available is solid polyurethane, which can be used to cast parts. For example, if you have a small, low stress part, machine one out of aluminum, and then make a mold from it and cast the rest.
Aluminum is not nearly as one-dimensional as one may think. Different alloys have different properties and a little research will go a long way. Look into the 7075 and 7068 alloys for high strength options.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 10-11-2008, 01:26
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
My favorite, better if it is donated.
R.C.
MadTown Robotics Team 1323
Alternative education EHaskins Chit-Chat 11 10-05-2007 21:46
Alternative Suction Cups Spiffizzle Pneumatics 2 13-01-2007 11:50
alternative to futaba? dradius Motors 8 14-06-2005 03:35
using alternative compiler Leav Programming 2 18-01-2005 15:30
A refreshing alternative to water... JC Denton Rumor Mill 16 04-02-2003 20:34
