Go to Post "It is a guaranteed fact that at least one rookie team will name their robot 'Chuck Norris'." - Tim Arnold [more]
Unread 04-11-2008, 10:53
ZeroValue ZeroValue is offline
FRC #2122
ZeroValue will become famous soon enoughZeroValue will become famous soon enough
Arrow Prototype Drive
This is what we are building in the off season. This frame is designed around a half-custom two speed transmission, cantilevered wheels, and synchronous belts. Questions, comments, and constructive criticisms are welcome.
Unread 04-11-2008, 10:57
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Prototype Drive
How are you planning on cutting all those holes? This thing needs to be done in 6 weeks
I like your use of belts vs. chain. Did you design the drive based on a given belt length, or are you using custom length belts?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 04-11-2008, 10:58
FRC #2122
Re: Prototype Drive
We plan to have the cnc machine running all night... and day.
Unread 04-11-2008, 11:02
FRC #2122
Re: Prototype Drive
We are using .5" wide L series belt, 92 teeth. I did a little monkeying with the wheel center to center distance, then added the tensioners in to take up the rest of the slack. The inventor sync belt tool was very helpful.
Joining the 900 Meme Team
FRC #0079
Re: Prototype Drive
Speaking from experience (http://www.chiefdelphi.com/media/photos/29306) it is doable by hand. It just takes a lot of time, and a lot of rookies (And yes, there is its twin in that picture, parts of that were lightened too
I also second the liking of the belt, from what Ive heard that would make it nice and quiet.
Unread 04-11-2008, 12:09
AndyB's Avatar
AKA: Andy Burchardt
Re: Prototype Drive
I wasn't focusing so much on the holes on the 1x1 crossbars, but more the interesting triangle-like shapes on the main drive rails.
Unread 04-11-2008, 12:34
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Prototype Drive
All I have to say, that this is beautiful. The patterns for CNCing are the same one's I'm using on our offseason prototype.
R.C.
MadTown Robotics Team 1323
Unread 04-11-2008, 12:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Prototype Drive
I'd still be a bit weary of going with belts in that application (for fear of jumping, skipping, breaking, etc), but this is one of the better implementations I've seen.
Are you planning to mill all those triangles? How much weight do you save for all that machine time?
Unread 04-11-2008, 12:41
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Prototype Drive
My gut says that with all those holes you're going to bend that frame on impact with an other robot.
Whats the wall thickness of that box tubing and have you done a stress analysis and bending calculations on the frame parts?
___________________
- Tennyson, Ulysses
Unread 05-11-2008, 10:06
FRC #2122
Re: Prototype Drive
We are using 2x1 with 1/8 side walls for the main frame members, and 1x1 with 1/8 sides for the two cross pieces. We haven't done any testing, but we are confident that it will hold. Last year our robot fell off the wall for every match, and we had over 20% more material webbed out. there is a forum somewhere here about basic cad for that robot that i posted when I was still green with the cad design/f.i.r.s.t., search for "tator".
The weight lost/cnc time ratio is fairly low. It's mostly a way to get some experience with the small cnc mill in the shop. Last year we sent the cad to the micron shop and had them machine and weld it. This year we plan to do more of it in our own shop. All of the kids in the shop during the off season mechanical team meetings have some experience with manual mills/lathes. We just don't know anything about the cnc part.
Unread 05-11-2008, 10:26
FRC #2122
Arrow Re: Prototype Drive
Here is a quick update with the welding plans added.
Unread 06-11-2008, 08:10
BanksKid's Avatar
BanksKid BanksKid is offline
..as The Circuitrunner.
AKA: Banks, Ethan Banks
FRC #1002 (Circuitrunners)
BanksKid will become famous soon enoughBanksKid will become famous soon enough
Send a message via AIM to BanksKid
Re: Prototype Drive
i have two words.......
WATER JET
it wouild also seem that you could loose alot of weight and machining time if you used flat plate as opposed to the tube frame.... from what i see, it appears to be slightly overengineered strenght wise..... but thats just me...
"WE HAVE A CAMERA RIGHT NOW!"
R.I.P. SAM
Unread 06-11-2008, 08:18
Dick Linn's Avatar
no team (Synergy)
Re: Prototype Drive
I'm not a fan of cantilevered wheels in general. Make sure the side rails are stiff enough not to twist.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 06-11-2008, 12:12
AdamHeard's Avatar
Lead Mentor
Re: Prototype Drive
I can't really speak for the belting, but everything else is looking like a decent start.
Don't worry, both the pocketing and cantilevered wheels are features that have been done before by teams, so assuming you've done the math, it should hold up just fine. What kind of machines do you have available, as that can affect how you would optimize your pocketing to minimize production time.
I'm personally a big fan of the standard hole pattern on the top as well; works out to be extremely convenient/worthwhile in the long run.
The slots for fasteners for what appear to be bumper mounts also look rather small (1/4"?). I would increase the fastener size on these as I imagine it would work out better in the long run (I'm imagining the a smaller diameter fastener tearing the plywood and becoming loose much faster than a larger one).
Unread 06-11-2008, 12:20
FRC #0079
Re: Prototype Drive
WATER JET
Someone correct me if Im wrong but I was under the impression you can only water jet plate. The issue being, the water tends to spread as it goes through the material.
Now laser cutting might work...
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
Team 1583's 6 wheel modular drive prototype NOV8R Robot Showcase 8 08-01-2008 11:57
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Team 610 Off-Season Tank Drive Prototype Jonathan Norris Extra Discussion 14 06-11-2006 01:59
