#16
Re: Prototype Drive
Generally some sort of material is put inside the extrusion so that it only cuts through one wall; 233 has done this, and I believe they use a 4x4 piece of wood inside of 4x4 extrusion when they waterjet that. I'm not sure if it would work with wood when applied to a piece with only 1" thickness, but I'm sure there is something that would.
#17
Re: Prototype Drive
I doubt that most have done the math. And a cantilevered wheel on a 1" x 2" aluminum frame member that has been skeletonized makes me leery of the durability. Obviously it depends on the amount of stick-out, but I was surprised at the twisting forces we encountered when using full 2" x 4" x 1/8" box aluminum. Your results may vary.
| pic: A closup view of our prototype worm-crab drive system. | AndyB | Extra Discussion | 6 | 20-01-2008 00:02 |
| Team 1583's 6 wheel modular drive prototype | NOV8R | Robot Showcase | 8 | 08-01-2008 11:57 |
| pic: 213 - Drive prototype teaser | Tyler M. | Robot Showcase | 10 | 07-01-2007 20:56 |
| Chain drive vs. cogged belt drive(timing belts) | LordBritten | Technical Discussion | 24 | 20-12-2006 23:07 |
| pic: Team 610 Off-Season Tank Drive Prototype | Jonathan Norris | Extra Discussion | 14 | 06-11-2006 01:59 |
