Go to Post Who would have thought a triangular robot would fit into a triangular goal :rolleyes: - Wayne Doenges [more]
Unread 07-11-2008, 03:03
dtengineering's Avatar
AKA: Jason Brett
Re: Motor that can be dropped off a building.
Originally Posted by NextPerception View Post
...A full body spinner has a spinning outside shell with sharp blades on it with a stationary inner chassis that has the drivetrain and spin motors as well as all the other robot essentials on it.
...The worst thing that could happen to me in battle is my center shaft bending or the plates that support the center shaft being tweaked so the center shaft iss no longer on the vertical axis...
I'm assuming this means that you mount the spinning outer shell of the robot directly on to the output shaft of the gearbox? (A photo or CAD image would be helpful) If so, I can see why the gearbox would be prone to failure.
Might I suggest building a custom shaft to support the spinning part of the robot ( you could make it out of 1" diameter solid titanium if you wanted) and weld that in to your frame, then use a pulley from the gearbox output shaft to spin the outer shell? That way (espeically if you build a bit of slip at high impact in to the belt) your gearbox output shaft will not be supporting the load... or impact... faced by the spinning outer shell.
Jason
Unread 07-11-2008, 09:46
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Originally Posted by ebarker View Post
just to be really clear.......
I'd bet any old transmission can survive the drop....
It is the 'undropping' process that is the real problem.
yes the drop aint the problem it's that whole slowing down thing
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 07-11-2008, 11:59
NextPerception NextPerception is offline
Sleep-Deprived
AKA: Matt
FRC #0437 (Richardson Robotics)
NextPerception has a spectacular aura aboutNextPerception has a spectacular aura aboutNextPerception has a spectacular aura about
Send a message via AIM to NextPerception
Originally Posted by artdutra04 View Post
Seven stories is a bit extreme, and way more than anything you'd ever see in combat robotics. Negating air resistance, any object through off a seven story building will reach a speed of about 20 meters per second (or about 45 miles per hour) when it hits the ground.
If you want to do some simple physics equations, you can calculate the exact final speed at impact from a seven story height, as well as how much kinetic energy the robot would have when it hits the ground. Compare this to the kinetic energy that the spinner would have at full speed, and you may find that a one or two story drop would probably* be a lot more realistic (and easier to design for).
* Just a swag. Do the math for an exact answer. There is great truth and wisdom to be held in the numbers.
I don't have the luxury of being able to design for anything less. My robots's spinning weapon strikes the opponent at 258mph maximum. that is more than my robots terminal velocity. This means I could drop the thing from 12 strories and it still wouldn't make a bit of difference.
Originally Posted by FourPenguins View Post
Have you looked at cordless drills? I have no personal experience, but a higher quality cordless drill is designed to take a beating. (Consider their normal operating environment on a construction site.)
I Have looked quite extensivley into them and they just wont fit.
Jason
I don't support my spinning shaft off of the gearbox. I already do something similar to what you describe. However, the motors for the spinning part are not the ones being questioned.
As far as a CAD image is concerned. here yah go. What that is am image of is the bottom of the robot with no bottom plate or spinning weapon visible.
Yes indead, so are you suggesting installing an airbrake on the robot?
What is this S - L - E - E - P you speak of?
Battlebots - My Robotics Website
Unread 07-11-2008, 12:46
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
have you actually tested the motors themselves in actual fights yet?
I think your problem may just be the gearbox being too weak. I'm not sure though.
You could always make your own gearbox .
EDIT: This whole concern is about your gearbox shaft getting damaged right? Have you considered using a racheting mechanism so that when it rapidly decelerates, it won't harm the gearbox shaft?
"we don't build robots, we build people"
Unread 08-11-2008, 15:05
Sleep-Deprived
AKA: Matt
yeah. I used the motors all last year in fights and even after one good fight you can already see the signs of them breaking.
Hey, Where Can I Get That Animation From The Kick-off? DaBruteForceGuy General Forum 20 05-01-2008 22:50
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Fixing the drill motor you dropped part 2 Jim Harbison Motors 2 24-01-2003 12:34
Fixing the drill motor you dropped Jim Harbison Motors 0 18-01-2003 16:14
building materials, can we use....... archiver 2000 2 24-06-2002 00:11
