Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 09-11-2008, 10:47
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: pic: 6 wheel suspension
To test how tight they have to be we will prop up the mecanums up with casters and than run with just the omni wheels. This should give us a good idea on the amount of slippage under pressure.
In studying drive system that teams have used through the years I have found that the mecanum system is the best except for the following items.
1. When going up ramps you must hit it square, but with this suspension you can hit it At an angle.
2. They are not great for pushing. With the added omni wheels it will give a little help (not a lot but some is better than none). We were in a match with our standard drive system and was up against a mecanum system and every time we tried to push and block them the just went around us like we were not their.
The good of the system out weighs the bad by a large amount. We have use omni drive in the past and are familiar with it but are just learning about the mecanum system and we need to know what to look out for with problems. Please let as know.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 09-11-2008, 11:42
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Are the two chassis sides linked (ie when one side articulates, does it carry the other with it)?
Unread 09-11-2008, 13:25
joeweber's Avatar
Coach team 1322
Drawings are at http://www.team1322.org/ideas.htm under "six wheel omni".
It is semi independent suspension on all wheels but the right is separate from the left. Because the frame attaches at the two point’s center of each drive half (between the omni and mecanum) the frame lifts about half of the front wheel rise. No springs are required, the weight of the robot should keep it all down. We may add springs later if needed. We are thinking that we could add pneumatic control to help with it, also use it to lift the front wheels to get up onto a step. The weight is approximately 25 lbs for each drive assembly.
Unread 10-11-2008, 22:09
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Very cool, not technically a suspension, but a flexing chassis (the only reason why i say that is because I work on cars all day at College). Although it is the closest thing to a suspension right now FIRST wise (from what I have seen). That idea would of be ideal for 2006 and 2007, maybe even 2009 if there is some sort of steep incline.
Like i said very cool and should come in VERY handy in the future since FIRST likes to use rams in some aspects of the games in the past.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 11-11-2008, 03:19
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
looks nice, although it might obstruct manipulator mounting. do you not need chain tensioners?
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 13-11-2008, 18:22
joeweber's Avatar
Coach team 1322
We have the sprockets and wraped the chain around them and worked out the distance. For the #35 chain it was 15in +/- 1/16. Doing this we do not need to tension the chain. Add a link than add 3/8 in, add two links add 3/4in.....
The game commin up will determin how we will attach the arms.
pic: 6 wheel omni directional with a suspension joeweber Extra Discussion 18 08-08-2008 19:31
pic: 6 wheel drive with a suspension joeweber Extra Discussion 18 07-08-2008 00:49
pic: 6 wheel drive with a suspension joeweber Extra Discussion 16 05-08-2008 00:32
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
