Go to Post I check CD while I'm waiting for ProE to reload everytime it crashes. So that's about 20 times a day :ahh: - Gary Dillard [more]
Unread 23-06-2002, 23:22
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Stretcher/goal issues-- PLEASE HELP ME!
Posted by colleen - T190 at 1/21/2001 2:52 PM EST
Engineer on team #190, Gompei, from Massachusetts Academy of Math and Science and WPI.
Hey y'all--
We built our stretcher and goal according to those lovely blueprints included in the manual (right next to the blueprints of the robot that came with it :-P)
Basically.. we're having issues about how far away the horizontal bar on both are from the edge of the plywood. Looking at kickoff pictures, it seems the kee klamps are right on the edge, but according to the drawing they are in a different place. What did everyone else do.. it's something we need to know ASAP.
Thanks so much...
Colleen
#0047 (ChiefDelphi)
Re: Stretcher/goal issues-- PLEASE HELP ME!
Posted by Raul at 1/21/2001 5:55 PM EST
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
In Reply to: Stretcher/goal issues-- PLEASE HELP ME!
Posted by colleen - T190 on 1/21/2001 2:52 PM EST:
As I understand it, the goals they used at Kickoff are wrong. The goal bases were originally about 34" wide and now are about 36" (don't remember the exact numbers). But, just do what the print says; that's what we did.
Raul
#0047 (ChiefDelphi)
is this correct?
Posted by Brian at 1/21/2001 7:18 PM EST
Student on team #56, Robbe Xtreme, from Bound Brook High School and Ethicon Inc..
In Reply to: Re: Stretcher/goal issues-- PLEASE HELP ME!
Posted by Raul on 1/21/2001 5:55 PM EST:
Well if i recall we put ours so the aluminum bar touched the PVC pipes on the goal is that correct?
#0047 (ChiefDelphi)
Re: is this correct?
Posted by Frank Toussaint at 1/22/2001 9:27 AM EST
Engineer on team #111, Wildstang, from Wheeling and Rolling Meadows and Motorola .
In Reply to: is this correct?
Posted by Brian on 1/21/2001 7:18 PM EST:
In the first goal we made, with the 34+ inch base, the aluminum pipe touched the vertical pipe. When we rebuilt it with the 36+ inch base the aluminum pipes were well away from the vertical pipes. The drawings that came with the kit are wrong (per FIRST); use the drawings dated 1/8/2001 on FIRST's documentation page on their web site: http://www.usfirst.org/2001comp/Docs/
#0047 (ChiefDelphi)
Posted by ChrisH at 1/22/2001 3:41 PM EST
Engineer on team #330, Beach 'Bots, from Hope Chapel Academy and NASA JPL, J & F Machine, Raytheon, et al.
In Reply to: Re: is this correct?
Posted by Frank Toussaint on 1/22/2001 9:27 AM EST:
: In the first goal we made, with the 34+ inch base, the aluminum pipe touched the vertical pipe. When we rebuilt it with the 36+ inch base the aluminum pipes were well away from the vertical pipes. The drawings that came with the kit are wrong (per FIRST); use the drawings dated 1/8/2001 on FIRST's documentation page on their web site: http://www.usfirst.org/2001comp/Docs/
Before you build make sure you have CURRENT documentation. This is a problem even in the real world, get used to it. We tossed all of our Rev 1 drawings to make sure we didn't get confused. It is also important to remember that documentation changes can happen through Team Updates as well as drawing changes.
#0047 (ChiefDelphi)
Posted by Janna at 1/21/2001 6:11 PM EST
Student on team #349, The RoBahamas, from International Academy and Ford Motor Company and Robert Bosch GmbH.
Colleen-
We built our goal according to the plans at first, but it looked messed up (poles all bent inward towards the bottom.) So we moved the kee klamps for the grabby-bar-thing right to the edge and the poles out until they lined up. Hope you figure it out.
Janna
#0047 (ChiefDelphi)
Posted by Suneet Upadhyay at 1/21/2001 6:50 PM EST
Student on team #599, Robo Dox, from Granada Hills High School and C.S.U.N. and NASA/JPL and various.
Hello.
Although I can't be sure as to the exact nature of your problem, I can say this: The blue prints that came with the manual are in some way inaccurate for the stretcher, as stated by team update #1. The new blueprints are in the competition documentation section of the FIRST website, under "Playing Field".
Hope it helps.
#0047 (ChiefDelphi)
Posted by Anton Abaya at 1/21/2001 9:31 PM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
try banging your head on the blueprints...it worked for me.
-anton
#0047 (ChiefDelphi)
Posted by Matt Leese at 1/21/2001 9:41 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Rochester Institute of Technology.
Posted by Anton Abaya on 1/21/2001 9:31 PM EST:
Well, just be sure you don't confuse the blood with the lines on the blueprints. What? No of course I didn't do that.........
Matt who let someone else build the goal
#0047 (ChiefDelphi)
Posted by mike o'leary at 1/22/2001 9:36 AM EST
Student on team #419, rambots, from bc high.
: try banging your head on the blueprints...it worked for me.
: -anton
thats cuz youre only an engineer, right?
mike oleary
#0047 (ChiefDelphi)
Posted by Anton Abaya at 1/23/2001 1:14 AM EST
Posted by mike o'leary on 1/22/2001 9:36 AM EST:
: : try banging your head on the blueprints...it worked for me.
: : -anton
: thats cuz youre only an engineer, right?
: mike oleary
right.
[IMG] code is Off
3D Studio Issues super_matt_250 3D Animation and Competition 6 14-02-2003 07:22
issues with if then else Andrew Rudolph Programming 1 15-01-2003 09:15
Time issues... Brandon Martus Announcements 2 17-05-2002 13:07
Duct Tape Issues? Joe Menassa General Forum 14 09-04-2002 18:25
Legality Issues Regarding Gears From other vendors kilpatrick Rules/Strategy 1 17-02-2002 09:04
