Go to Post if sleep is essential, then yeah, I'm in trouble. - Eria4044 [more]
Unread 09-11-2008, 19:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 6wd chassis
Originally Posted by sdcantrell56 View Post
How would 1/4" plate save money over 1/8" plate?
It wouldn't.
2001-2004: Team 100
2006-Present: Team 254
Unread 09-11-2008, 20:01
Joining the 900 Meme Team
FRC #0079
Originally Posted by Cory View Post
It wouldn't.
Well, it would if you kept breaking it and having to replace it. Obviously you need to make sure that 1/8 is strong enough to do what you want. You do NOT want to be burning money having to replace parts because they werent designed properly.
Unread 09-11-2008, 20:24
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
1/4" thick is always more expensive because it is more material. In the age of bumpers, a properly supported 1/8" plate will more than stand up to the abuses of FIRST. If you want to increase the strength substantially without increasing weight by too much you could bend the plates on the top and bottom to create a flange. This will increase the stiffness of the plate dramatically.
Mentor 2415
Unread 09-11-2008, 21:29
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Flanges are pretty awesome things. Here on 148, we like them. If you have access to sheet-metal or metal bending capabilities, it will help you make all kinds of very strong, very light pieces.
To paraphrase Ferris Bueller:
"They are SO choice. If you have the means, I highly recommend adding a few."
Unread 09-11-2008, 22:31
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
If you have the patience to dig through it, there are a number of examples on how the location of material affects the strength and stiffness of a beam in this thread. http://www.chiefdelphi.com/forums/sh...ad.php?t=67605
Mark
Brick walls are for other people. - Randy Pausch
Unread 09-11-2008, 23:50
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
it is 1/8" alluminum 5052 alloy, so it is harder and stronger then other alloys.
295 Team Captain
Unread 10-11-2008, 00:15
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Why not use 2024 or 7075 if your not welding anything to those pieces. 7075 sheets have a brinell of 150 and a yield of 65 ksi.
R.C.
MadTown Robotics Team 1323
Unread 10-11-2008, 01:25
AdamHeard's Avatar
Lead Mentor
It's not always a matter of "X material has a higher yield than Y material".
5052 is commonly used in sheet metal applications as it is much easier to bend and flange. Yes, 7075 is harder and has a higher yield strength.... but, good luck shaping it as easily as 5052. In fact, the low radius bends you see on most sheet metal parts in FIRST (148, 228, Kitbot frame) would probably crack 7075 rather than nicely bend it.
Unread 10-11-2008, 01:27
R.C.'s Avatar
I didn't think he was going to bend it, as shown in his CAD drawing. Yes you are right about the 7075 cracking.
R.C.
Unread 10-11-2008, 01:42
AdamHeard's Avatar
Lead Mentor
The next logical iteration in the design (supported by some recommendations by some knowledgeable people) would have been to flange it.
Unread 10-11-2008, 03:58
Cory's Avatar
AKA: Cory McBride
Using 7075 or 7068 for the sideplates of a drivetrain is a total waste of money and complete overkill in my (not) so humble opinion. Tons of people have made similar designs with plain old 6061 and it works just fine.
It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work.
2001-2004: Team 100
Unread 10-11-2008, 09:00
AKA: Sean
I completely agree with you cory. The only places where I see 7075 as having a noticeable impact on performance is on gears and shafts where strength is very important and there is a constant load working on the shaft. Adding flanges to the sideplates will increases the stiffness much more than just switching to 7075 aluminum. Also 7075 is very expensive stuff.
If anyone wants to see flanges, look at my last drivetrain I posted http://www.chiefdelphi.com/media/photos/32013?
Mentor 2415
Unread 10-11-2008, 00:33
Brandon Holley's Avatar
Nice.
And I agree with JVN here...flanges are an awesome way to strengthen something up and keep it light.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-11-2008, 00:47
R.C.'s Avatar
Originally Posted by Brandon Holley View Post
Nice.
It would help to see some pics of this properly implemented.
R.C.
pic: FRC1293 Prototype 6wd Chassis Thermal Extra Discussion 16 06-01-2009 23:12
6WD Chassis Stiffness vs. Maneuverability IKE Technical Discussion 35 07-12-2008 16:04
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
Need pictures of chassis for 6WD team2061 CAD 6 24-12-2007 14:51
pic: 6WD Module Madison Technical Discussion 20 12-01-2007 10:09
