Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
Unread 09-11-2008, 21:57
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Lightbulb Software for determining the parameters of threaded products
Hi FIRST'ers I know its been a little while but I'm back with a goodies.
First off please forgive me if this in the wrong thread but it didn't really fit anywhere else.
While checking out some stuff for a team I help out I came across a neat program for you gear designers.
Just tell it wanted/needed rpm's, wheel size, and other info and it gives you the thread counts ect... for what I've been told. Truthfully its above my pay grade but I'm sure some of you might find it more useful. Anyhow I c/p the info on it and you can check it out and see if its something you might like.
QMSys Threads provides thread data on pitch diameters, major diameters, gage data, part data, helix angles, product and gage tolerances, crest and root flats, wire sizes, constants, and just about anything on threads one needs to know. The software assists users in the following activities:
- thread measurement and control – determining the nominal and limit sizes of external and internal threads
- product design – selection of threaded joints.
The trial version of QMSys Threads is available for immediate download:
http://www.qsyst.com/html/software_en.htm
Hope it helps someone...
-p
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Determining pulse width for the GTS? Uberbots Programming 6 28-01-2007 21:12
Parameters software Astronouth7303 Programming 5 27-06-2006 20:28
Parameters [Dimensions] for the controls? Crazy Control System 9 21-01-2005 22:23
Good news for those who liked the old threaded view Brandon Martus Announcements 6 24-11-2001 21:22
