Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Go Back   Chief Delphi > Technical > CAD
Unread 06-11-2008, 21:11
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
MasterCam, Solidworks & CNC Help
Hello CD,
I am currently using MasterCam for our CNC. I am having some problems with MasterCam, Solidworks, and the Techno Isel CNC software. Our team and I prefer to draw in Solidworks and then go to MasterCam to put the toolpaths on the object needed to be machined.
-MasterCam will not open a part directly
-The only way is to import the file is by using the feature Manager from solidworks import to Mastercam feature
So it imports, I put the paths on it. The model is 3d. I used the contour feature and and the wireframe view and the chain. I put in all the right info and it shows me what it is suppose to do. Then I send the G code to the Techno software and it gives me an error. Can anyone help me or tell me what I am doing wrong.
Thanks,
-RC
R.C.
MadTown Robotics Team 1323
Unread 07-11-2008, 00:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: MasterCam, Solidworks & CNC Help
Originally Posted by rc_cola1323 View Post
Hello CD,
Thanks,
-RC
Way too little information here for us to help you. What error are you getting? This is while transferring the program, or while attempting to run it?
MasterCAM opens native SW files, depending on which versions you have. MasterCAM X will open SW2005 and previous files. X2 will open 2007 and I think 2008. X3 would presumably open 2009 as well, but I've never used it to check.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-11-2008, 00:51
R.C.'s Avatar
When opening a solidworks file is says cannot find parasolid. During the CNC process it won't start the nc file but it will load it up.
R.C.
Unread 07-11-2008, 02:38
Cory's Avatar
AKA: Cory McBride
If it won't load the Solidworks file, it means your version of MasterCAM is not new enough.
You need to find someone with experience using your particular machine to resolve the second problem. Better yet, call the manufacturer.
2001-2004: Team 100
Unread 07-11-2008, 02:45
R.C.'s Avatar
Thanks Cory but we MasterCAM X3 and Solidworks 2009. Also when we start to zero the machine in the z (it is suppose to go down and touch a pad to find depth), it goes up instead of down
R.C.
Unread 07-11-2008, 03:19
Cory's Avatar
AKA: Cory McBride
Call your MasterCAM retailer and call the CNC manufacturer. MasterCAM should have a plugin available to give compatibility for 2009 files. Whoever makes the machine should be able to help you troubleshoot your problem. You're probably wasting your time on here, as it sounds like something very specific that someone would have to see to figure out.
2001-2004: Team 100
Unread 07-11-2008, 15:51
R.C.'s Avatar
Thanks Cory, I called them up and they said that they don't currently support solidworks 2009 yet, it will be supported in a service pack update for Mastercam X3.
R.C.
Unread 09-11-2008, 20:48
R.C.'s Avatar
Another question, does having the right post processor matter? I think that is the problem, on the laptop we have the file but when we use the desktop or my laptop (which doesn't have it) it messes up.
R.C.
Unread 09-11-2008, 22:42
Cory's Avatar
AKA: Cory McBride
It's definitely important. You don't necessarily need one specifically for your machine. I use the generic fanuc 3 axis post and it works fine on a Haas, but it may not work as well on your machine. You can copy the post processor definition from one computer to the other though.
2001-2004: Team 100
Unread 09-11-2008, 23:03
R.C.'s Avatar
Are any of the defaults with MasterCAM workable? We are going to try the real post processor one tomorrow, thanks Cory for the confirmation.
R.C.
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
CNC Mill Help Rickertsen2 Technical Discussion 8 25-08-2004 00:59
Help - G-Code Circular Motion for CNC Milling sanddrag Technical Discussion 15 18-08-2004 23:00
cnc/cad/cam help chbix Technical Discussion 12 07-07-2004 22:40
