Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Unread 12-11-2008, 08:02
Re: Potentiometers in Analog Inputs
Originally Posted by AustinSchuh View Post
While you may have done this to simplify things for non EEs, I find your choice of symbols for current very unique. Most, if not all, EEs use the symbol "I" for current. I thought you were talking about capacitance there for a moment.
I used C(urrent) instead of I(mperage?) to make it easier for non EEs. I find VCR and PVC easy to remember.
But yes, I use "I" in real life.
Unread 12-11-2008, 08:57
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Gustavo,
To answer your question about whether the 5W potentiometer is okay -
Yes it's okay to use but I would recommend that you find something like a 220Ohm or higher potentiometer with 1/4W power rating. It's generally wasteful to use > 1W for a sensor and it will probably get warm. But it will work.
There is an upside to using a 22 Ohm 5W pot, though - it's probably a very durable part and unlikely to be damaged during competition. There's something to be said for ruggedness.
current needed = 5V over a 22 Ohm resistor = 5/22 Amps = 0.23 Amps (which is less than the 0.75 Amp rating for each pin of the Analog Breakout module)
power dissipated by the 22 Ohm resistor = 5V * 0.23 Amps = 1.14W (which is less than the 5W rating for the part)
The 2009 Analog Breakout module can supply enough power and the NI 9201 Analog Input module will provide 10 bits of resolution between 0 and 5V (ie the full range of the potentiometer).
Be very careful to connect the wiper of the pot to the analog input. If you connect 5V power to the wiper, you'll have a variable current draw from the power supply which will short circuit the supply at one end of the potentiometer's range.
Russ
Unread 12-11-2008, 11:36
Dick Linn's Avatar
no team (Synergy)
You can find variations of this chart (Google image search ohm's law).
ID:	6949  Click image for larger version
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 12-11-2008, 23:22
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Thanks for the basic EE training...
Sorry about hijacking your thread Gustavo
Help! Analog Inputs!! brennerator Programming 7 11-02-2007 15:48
Analog Inputs bush Programming 5 13-03-2006 17:49
Analog Inputs prob. Bharat Nain Programming 2 07-02-2004 20:48
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
Analog Inputs 316_programer Technical Discussion 2 05-02-2002 05:53
