Go to Post You move on because FIRST isn't about the penalty or the un-penalty or whose robot is agressive and who is timid. - Collin Fultz [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 12-11-2008, 15:16
bernieseaholm bernieseaholm is offline
FRC #2960 (automation nation)
bernieseaholm is an unknown quantity at this point
[OCCRA]: spike relay polarity question
it seems that regarless of how the spike relay is connected, we are only able to have it switch to "red", the trigger functions does not switch to "green" when depressed. we do not have it hooked up to a motor to reverse direction, only a solenoid valve. we have tried different pwm cables, different spikes, same result.
any ideas as to why this is occurring and will it matter if only switching the solenoid?
thanks
bsimms
Unread 12-11-2008, 16:43
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: spike relay polarity question
To get it to go green ( other function) you need to push another input.
Question? Are you using the default code? If so refer to the chart that is on the IFI Website. It is a PDF File.
Mike Martus
Spike relay question Zack Briggs Electrical 17 19-02-2008 14:48
Spike Relay Wire Gauge sparrowkc Electrical 7 12-02-2008 14:26
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
