Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 14-11-2008, 08:08
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
[OCCRA]: Championship Info
Several teams are asking the same questions so here they are:
1. ? How are teams ranked? Please refer to the 2008 OCCRA rules. Basically... the teams are ranked upon their 12 best scores. These are averaged to get a number. The higher the number the higher the ranking.
2. ? What is the selection process? Please refer to the 2008 OCCRA rules. Starting with the highest ranked team each team will select an alliance partner. The top 6 teams CANNOT select each other. Selections continue until all teams are selected.
3. ? Who plays Whom? Please refer to the 2008 OCCRA rules. We use a double elimination Tournament Tree that matches teams using the NCAA system of highest plays lowest. If a team loses a match they go to the losers bracket. In the finals there will be 1 team from the main bracket and 1 team from the lossers bracket to play for the championship. Remember you only have to beat a team by 1 point. All ties will be replayed. The FINALS match is best 2 of 3. All others are single games.
4. ? Can we have a copy of the tree you will be using? We will make that available as a pdf as soon as possible. It is the same as last year.
5. ? How many seeding matches are at the Championship? There will be two seeding matches at the championship. Then a brief pause as we calculate the final rankings. When complete each team will send 1 team represenative to the field for selection process. Please develop your list of whom you want to form an alliance with..... be prepared to select a team.
6. ? Is the placebo available if my alliance partner breaks in a match? NO Please refer to the 2008 OCCRA rules
Mike Martus
Championship Info vikram31291 General Forum 5 05-03-2007 18:59
[OCCRA]: Championship bracket JBotAlan OCCRA Q&A 1 23-11-2006 14:40
[OCCRA]: FOR ALL OCCRA TEAMS:Team Info Request Nate Smith OCCRA 0 15-11-2004 23:27
[OCCRA]:35H30 sprockets info? Adam11 OCCRA Q&A 1 04-10-2004 22:20
Championship info from FIRST Mike Martus Championship Event 37 15-11-2002 16:29
