Go to Post Too often we like to forget that it takes an insane amount of hard work to even have a chance to overcome raw talent. - Paul Copioli [more]
Unread 14-11-2008, 10:57
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
Mecanum Drive Train
Hi, we are planning on using a mecanum drive train this year and im not 100% sure on how to set it up. if anyone can help me that would be great. thanks
Unread 14-11-2008, 11:58
Re: Mecanum Drive Train
First, don't commit to a drivetrain until after kickoff. It's the worst thing you can do. Prototyping is fine, but planning before Kickoff is asking for the GDC to outlaw that design, or designing a game (or kit) so that it won't be the best.
Now, setup: 4 motors, 4 gearboxes, 4 mecanum wheels, and a fairly standard 6WD/4WD frame. Rig one motor to each gearbox, and arrange the wheels in the frame so that the tops look like either an X or an O. (Both will work, but the X pattern on the top resists spinning better than the O.) Connect the gearboxes and turn it over to the programmers so they can figure out the coding.
Unread 14-11-2008, 12:07
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
If you're going to build a new (as in new to yourself) drive system, you must first know how it works. A good whitepaper that discusses the kinematics of a mecanum can be found here: http://www.chiefdelphi.com/media/papers/1836.
Read it, learn it, know it. It will will help in your planning. Also, do a quick CD Media search for pictures of mecanums to get your brainstorming going.
Oh, not to mention the break-through 6wd-mecanum suspension, but here's a good example. And then there's 488's prototype mecanum.
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
Unread 14-11-2008, 12:10
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
we build our own omniwheel drive system from scratch including wheels but i believe you can order mecannum wheels off of FIRST.
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 14-11-2008, 12:59
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Actually, its Andymark that sells them.
http://andymark.biz/mecanumwheels.html
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 14-11-2008, 13:21
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
If your team is completely unfamiliar with how a mecanum system(or for that matter any other drive system) works then I would highly suggest that you do not try it during the build season.
A good drivetrain is (usually) paramount to having success during the season, and it becomes that much more difficult if you need to learn that drive system during the build season.
I would also echo EricHs' warning. Don't lock yourself into a drivetrain (or any other robot part) until you understand the challange given at kickoff. To do so could possibly lock yourselves into a design that may not work.
___________________
- Tennyson, Ulysses
Unread 14-11-2008, 14:31
dtengineering's Avatar
AKA: Jason Brett
You can find lots of examples of mecanum robots on Youtube. To get started, search for "1346 mecanum" and you'll see the one we built a couple years ago.
While I would suggest that you heed the advice about not committing to a drive train until the game is announced, there is absolutely nothing wrong with preparing to build a mecanum once you know it will match your team's game strategy. The worst thing that will happen is that you will learn a lot about mecanum (and other omni-directional) drive systems.
There are a GREAT many forums here on CD discussing the benefits/disadvantages of mecanums and tips/techniques for building them.
Jason
Unread 14-11-2008, 16:04
Sam2197's Avatar
Team Role: Driver
thanks for all the help. regardless we are going to prototype a drive system sometime hopefully in the next month. i've read about how they work and everything but i guess i wont be exactly sure until i see it. and what is the best way to attach the wheels to the gearbox and what is the best gearbox to use
Unread 14-11-2008, 16:52
Sprocket and chain is the best, though some will prefer direct drive. The best gearbox is a relatively fast one; mecanums don't transfer power in the same way as a 4WD. (Hint: Toughbox, unmodified, is/can be too slow even on a 1:1 ratio to the wheel.)
Unread 14-11-2008, 16:57
Sam2197's Avatar
Team Role: Driver
so is there any gearbox that would be best. or would we need to modify any gearbox we get
Unread 14-11-2008, 17:48
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
you could use the banebot transmission, they are pretty fast(when directly driven to the wheel) although reliability is an
issue
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 14-11-2008, 18:06
AndyB's Avatar
AKA: Andy Burchardt
Try 9:1 banebots. Thats what 1675 used this year with 6" mecanums and they were pretty quick.
Unread 14-11-2008, 21:24
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
I've been discussing Mecanum with my team as well and completely agree that committing before the 4th at bare minimum is an extremely bad idea in the sense that it could just not work for the game or at the very worst GDC could outlaw it. =/
however, [as is the case with my team *currently*] not even thinking about it do parts/labor/programming needs and the fact we've never done it before is... well, just an excuse. Nobody did it before they did it ya know? that's plain logic. If anyone remembers any of 279's robots, they can see that tank drive with an occasional perpindicular omni has been used EVERY year since Jake in 2001. I think, being our 11th year, it's time to try something new, but nobody's willing to commit the resources. I'm pretty sure that even though 6w with a larger or offset middle wheel has been the driveline of champions the past few years the mentors on my team will still not consider an alternate driveline. my question to CD is who wants to help me/us do something differant assuming something doesn't develop before... say december?
Btw, this is my first post!!! so a little about myself: My name is Nick Burmeister, though most call just call me Burmeister. I'm a Second Year student on Tech Fusion - 279. I was the 2008 Driver and Student-head of building driveline.
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 14-11-2008, 22:02
Maybe you should suggest to your mentors that they come around CD sometimes and see the various ideas that get floated around. I've seen some crazy ideas, like omnitracks. (omniwheel on a tank tread) Who knows? They might have some ideas themselves.
And, of course, this is probably one of the top 3 most helpful places to a FIRSTer. #1? The FIRST website. #2? (tie) CD and The Blue Alliance (TBA).
Unread 15-11-2008, 21:47
What Time Is It?
i've showed all of the students on the team the various drivetrains that are on CD and some of the mentors.
Questions on Mecanum Drive Train charmed862 General Forum 3 09-01-2008 22:23
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
Drive Train archiver 2000 1 24-06-2002 00:37
