Go to Post keep making a difference out there everyone...slowly but surely everyone will catch onto FIRST and then the world will be a better place :) - tiffany34990 [more]
Unread 15-11-2008, 21:56
Re: Mecanum Drive Train
Originally Posted by Burmeister #279 View Post
i've showed all of the students on the team the various drivetrains that are on CD but i think that the team as a whole is relying too much on the mentors.
Show the mentors as well as the students.
Unread 16-11-2008, 02:14
dtengineering's Avatar
AKA: Jason Brett
Originally Posted by gorrilla View Post
you could use the banebot transmission, they are pretty fast(when directly driven to the wheel) although reliability is an
issue
Sigh... reliability is not an issue with the CIM planetary gearbox from Banebots. At least no more so than for any other gearbox used in FRC. There was a problem with their first batch of trannies, which, unfortunately, got shipped out as part of the KoP two years ago. Banebots went to great expense and effort to fix the problem in time for competitions and has further improved their product since then. Unfortunately it is the nature of (many) people to remember the initial problem, rather than the excellent committment to service and subsequent improvements that Banebots has made. We were one of the first teams to identify a problem in the original KoP trannies, and have since taken advantage of the free upgrade that BB offered to ALL FRC teams and have been running BB trannies on our mecanum for the last two years with no issues.
In fact BB trannies, or other direct connect transmissions (where the wheel is mounted directly to the output shaft) make for, in my experience, the most reliable drivetrain as the most common point of failure... the chain or belt... is eliminated from the system. Just make sure the output shaft is supported on the outboard side of the wheel!
An additional advantage of the BB trannies is that you can order them in a wide range of gear ratios, and can convert from one ratio to another (with some limitations) if you aren't happy with the performance.
Yep. There was a problem with the Banebots trannies two years ago that was quite disruptive. But it is hardly fair to question the reliability of the current trannies given the fact that BB stood behind their product, solved the problem in short order, upgraded over 3,000 trannies for free, and has since improved them even more.
Jason
Unread 16-11-2008, 10:27
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
i agree with that. our rookie year we had the banebots as kop gearboxes and we loved them. our robot was pretty quick that year. we are probably ordering them again this year
Unread 16-11-2008, 16:55
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Jason
I know, but thats not all i was considering. has anyone every seen a toughbox fail?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 16-11-2008, 17:29
No. However, you can't use them in their unmodified state as mecanum gearboxes and expect speed and maneuverability to be the best. I've seen that firsthand. There are modifications that can be done to improve speed. I don't know how effective those would be when used in a mecanum drive.
Unread 16-11-2008, 17:36
Sam2197's Avatar
Team Role: Driver
i agree. last year the toughboxes were really slow. reliable but slow. and i dont think you can speed the up all that much
Unread 16-11-2008, 17:41
Billfred's Avatar
Billfred Billfred is offline
You could, in theory, get a wide range of speeds out of a Toughbox; the easier ways to get that range of speeds tend to involve factors outside of the gearbox itself. (Wheel size, sprocket choice, etc.)
Unread 16-11-2008, 17:46
Or, you can try something like this. For a 6" mecanum, a roughly 1:1 out of the Toughbox wasn't enough last year.
Unread 16-11-2008, 18:11
gorrilla's Avatar
AKA: adam spears
WOW,
Adam Spears
Unread 16-11-2008, 19:35
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Or you can try AndyMarks new planetary. Had one in my hand Saturday, real sweet. 3.7:1 would work well with the 6" mecanums.
Unread 16-11-2008, 20:51
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Last year we had used the AndyMark 8" Mecanum Wheels along with the AndyMark Toughbox gear boxes
One thing I didn't see anyone mention, is that when you mount them mount them in a square, so as in the distance from the middle of the wheel is the same front to back as it is left to right, it makes it easier come programming and movement. It makes since when you think of it, the rollers are mounted at a 45 degree angle.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Questions on Mecanum Drive Train charmed862 General Forum 3 09-01-2008 22:23
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
Drive Train archiver 2000 1 24-06-2002 00:37
