Go to Post I tried, but our freshmen lost enthusiasm about filing the blocks of aluminum I gave them into Andymark Performance Wheels after only a few hours! - Greg Woelki [more]
Unread 15-11-2008, 13:37
mogli mogli is offline
mogli is an unknown quantity at this point
modules for RC PLANE
Hey guys i need help regarding modules.. me and my friends have built a rc controlled plane which is pretty gud at fluing and also can carry a payload of 5 kgs with 10 cc engine.... but the problem is there is no avionics onto the plane.. like sensors and modules for stabalising plane while cruising.... i mean for sudden change in wind may take our plane down ... so i need help lik.... sensors or readymade modules which are good at it...
Unread 15-11-2008, 14:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: modules for RC PLANE
What's your price range? Cloudcap and Micropilot make autopilot modules for UAVs that will definitely keep a plane in the air, but they're very expensive (thousands of US dollars).
On the much lower end of the cost scale, there are infrared units that track the horizon, and will try to keep the plane level, by mixing the pitch and roll controls. (I'd estimate this would cost around $150 USD.)
As a sort of medium-cost option (several hundred US dollars), something like the Innovation First Mini-RC controller could be used to interpret the control inputs from your radio receiver, and mix them with sensor inputs from accelerometers, compass sensors, etc. to prevent sudden motions. This will require a lot of programming, and certainly wouldn't be easy.
But here's the big catch, however you do it: if I recall correctly, India's Air Ministry is very strict about its regulations for unmanned aerial vehicles. Make sure that you're not doing anything against their rules. A number of Indian university-based competitiors in the International Aerial Robotics Competition have suffered because they weren't allowed to test their aircraft freely.
Overall, unless you've got access to significant amounts of money, and have the time to build and integrate sensors, you probably would be better served by just watching it closely when it flies, and learning to fly it better. See if you can track down an experienced model plane pilot in your area who can give you some lessons.
Also, this forum is generally dedicated to the FIRST Robotics Competition. Your questions are certainly welcome, but be aware that many topics on this site are specific to the hardware used in FIRST.
Unread 15-11-2008, 15:05
By any chance, is this airplane built for the SAE Aero Design Competition? If so, which class?
Unread 15-11-2008, 18:21
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
I would use something like a basic stamp and acceleratometers. One meter in each wing to sense large, sudden changes in acceleration that were not given by the controller. With the two axis ones from parallax, you could also stop the plane from stalling and dropping suddenly. Stamps and their parts are cheap, light, and easy to program. They use a port of basic. I have a BS2 that I am going to use in a submarine eventually.
No offense, but a mini FRC is a lot more expensive and heavier. They also require the MCC18 compiler or something similar, where as the stamp's programmer is free from Parallax.
Good luck
Unread 16-11-2008, 08:40
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I have a brand new gyro autopilot for sale.
It has an on board gyro that keeps and plane flying straight and level and a barometric pressure sensor that can sense if the plane is going up or down.
When set up correctly the plane will take off on it's own and fly straight. Just give it full throttle and step back.
You can also turn it off/on from the transmitter. You can put the plane in a full blown, straight down spiral, hit the swith and the plane will level out on it's own.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 16-11-2008, 11:11
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Check this out.....
http://diydrones.com/profiles/blog/s...ogPost%3A44817
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Source Code for Built-in Modules weissert Programming 1 24-10-2007 15:41
air speed sensor for rc plane Greg Needel Technical Discussion 19 07-10-2005 23:43
IDs for Boarding Plane MattK General Forum 40 09-04-2003 23:03
Extra Plane Ticket...Hartford to Orlando for this Wednesday! archiver 2000 0 23-06-2002 22:41
RF Modules archiver 1999 1 23-06-2002 22:06
