Go to Post I mean I am a pocket protector kind of guy. - techhelpbb [more]
Unread 16-11-2008, 12:23
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Timing Belts for 6W Drive
My team is making a basic 6 wheel drive base with the IFI KITBOT, and we are interested in using timing belts instead of chain. We're planning to have the SuperShifter transmissions between the front and middle (lowered 1/8") wheel, with 2 belts on each side, one connecting transmission/front-wheel/mid-wheel and another connecting mid-wheel/back-wheel.
We're using 6 grey Andymark wheels from the KoP and 3/8" d steel axles. This robot is meant to be a durable and fast (~11 fps) base for drivers to practice with.
What belts and pulleys we should use (manufacturer, width, part #, etc.)?
Do we need to buy the exact length, or is there a way to cut and re-attach (could we use the 10' Gates belting from the kit)?
Do we need a way to tension, or will there really be no stretching?
Any suggestions?
Thanks for all of your help!
Unread 16-11-2008, 13:18
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Timing Belts for 6W Drive
We have used 6 wheel drive for many years, but #25 chain for the drive. We have considered using belts, but have felt that belts take a little more width away from the robot footprint, where space has been at a premium. Belt tension is extremely important with belts, so put a tensioning adjustment into your design for every belt. I would also suggest using a COTS belt rather than try to put a custom length onto your machine.
We have also used the drive configuration you are considering, but would suggest runnng the wheel to wheel belt from the mid wheel to the front, rather than the rear. When you get into a pushing match, the front wheels will not provide any traction as they will lift. I would also suggest you consider a drive belt to each wheel, so you can still drive, even if several belts break. Design so belts can be changed easily, and keep spares on hand. I haven't looked at the load capabilities of belts, but #25 chain can take 750 lbs of load. The only time we have broken a chain is whe another robot part got in betwen our sprocket and chain, deleoping tremendous load, and we were still able to compete. PM me if you need any other info.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 16-11-2008, 13:50
ttldomination's Avatar
Sunny
Might i advise that you/your team not make any major purchases/decisions before the game is announced...Bill and Dave have strongly advised that teams don't make major plans....
1648: 2013-2014
5283: 2015
Unread 16-11-2008, 14:36
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
We used belts on one of our robots a couple of year ago. We found that if you dont tension the belts then they will skip. It doesnt seem to hurt performance, but it can scare people with how loud the skipping is.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 16-11-2008, 15:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If your belts are slipping, it has to hurt your performance-it means you're losing tons of efficiency.
I believe 125 used belts either last season or in 2007, and they did not like them at all. If I remember correctly they ended up swapping them for chains. Do a search and you can find the thread about them.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-11-2008, 17:26
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
125 actually used belts this past season with very positive results if I'm not mistaken. I think they said they never had a failure.
Mentor 2415
Unread 16-11-2008, 18:15
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
wait, why not just use v-belts?(as in what are the advantages of using timing over v-belts)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 16-11-2008, 18:19
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Just stick with chain... it works. I've seen a couple teams try timing belts, and I haven't heard anything positive yet. Timing belts are very tough to do in high load situations, chains are designed for higher loads. Why change what's proven to work?
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 16-11-2008, 18:21
AKA: Sean
V-belts require very high tension to work which equals high friction and inefficiency. Timing belt is a much better option in every factor except perhaps cost although it is definitely worth it to not use v belt
Mentor 2415
Unread 16-11-2008, 19:17
Cory's Avatar
AKA: Cory McBride
Oops. Maybe I totally invented that in my head then.
I recall someone using belts recently and not liking it much. Guess it wasn't 125.
2001-2004: Team 100
Unread 16-11-2008, 21:37
AKA: Sean
There was one team that tried v belts I believe in 2007 and the belts failed miserably. A couple teams have used timing belts successfully such as team 125 and team 118 uses them to some extent. You just have to design for them instead of using them the exact same as chain. For instance, you need to have a lot of wrap around the pulleys and the belt must be tensioned properly, although once tensioned the belt stretches much less than chain.
Mentor 2415
Unread 16-11-2008, 22:47
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Maybe it was 499 you were thinking of?
http://www.chiefdelphi.com/forums/sh...ad.php?t=61512
Unread 16-11-2008, 22:55
Brandon Holley's Avatar
Cory,
We did use belts this season (2008), but ended up having a lot of success with them. We used 25 chain in 2007.
As for the original topic,
I have posted on a few threads already (a quick search should churn them up). Belts are definitely something teams can do, but as stated above, tension is key with them. We used kevlar reinforced belts which basically eliminated "stretching" so we did not need an active way of adjusting the tension. I would suggest doing a lot of research to make sure they are something you want to consider.
Right now I could not tell you what our plan is for the upcoming season. We are proud we used belts effectively and we will see what the game is before we commit to using them again.
Let me know if you have any more questions.
Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-11-2008, 09:12
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
did 118 use that ajustable v-belt stuff to power form the v6 to the swerve drive wheels
Brandon could you post or pm me were you got you belts
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 17-11-2008, 11:12
AKA: Sean
I'm almost positive that 125 purchased there belts from sdp-si.com They have a great selection and some helpful calculators as well.
Mentor 2415
Timing belts kajeevan General Forum 6 13-08-2008 13:59
Join timing belts GMAdan Technical Discussion 5 19-04-2007 16:03
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
