Go to Post There is more to our team than my hair, you know. :P - thefro526 [more]
Unread 16-11-2008, 15:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Timing Belts for 6W Drive
Originally Posted by Mechkrunch View Post
We used belts on one of our robots a couple of year ago. We found that if you dont tension the belts then they will skip. It doesnt seem to hurt performance, but it can scare people with how loud the skipping is.
If your belts are slipping, it has to hurt your performance-it means you're losing tons of efficiency.
I believe 125 used belts either last season or in 2007, and they did not like them at all. If I remember correctly they ended up swapping them for chains. Do a search and you can find the thread about them.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-11-2008, 17:26
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
125 actually used belts this past season with very positive results if I'm not mistaken. I think they said they never had a failure.
Mentor 2415
Unread 16-11-2008, 18:15
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
wait, why not just use v-belts?(as in what are the advantages of using timing over v-belts)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 16-11-2008, 18:19
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Just stick with chain... it works. I've seen a couple teams try timing belts, and I haven't heard anything positive yet. Timing belts are very tough to do in high load situations, chains are designed for higher loads. Why change what's proven to work?
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 16-11-2008, 18:21
AKA: Sean
V-belts require very high tension to work which equals high friction and inefficiency. Timing belt is a much better option in every factor except perhaps cost although it is definitely worth it to not use v belt
Mentor 2415
Unread 16-11-2008, 19:17
Cory's Avatar
AKA: Cory McBride
Oops. Maybe I totally invented that in my head then.
I recall someone using belts recently and not liking it much. Guess it wasn't 125.
2001-2004: Team 100
Unread 16-11-2008, 21:37
AKA: Sean
There was one team that tried v belts I believe in 2007 and the belts failed miserably. A couple teams have used timing belts successfully such as team 125 and team 118 uses them to some extent. You just have to design for them instead of using them the exact same as chain. For instance, you need to have a lot of wrap around the pulleys and the belt must be tensioned properly, although once tensioned the belt stretches much less than chain.
Mentor 2415
Unread 16-11-2008, 22:47
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Maybe it was 499 you were thinking of?
http://www.chiefdelphi.com/forums/sh...ad.php?t=61512
Unread 16-11-2008, 22:55
Brandon Holley's Avatar
Cory,
We did use belts this season (2008), but ended up having a lot of success with them. We used 25 chain in 2007.
As for the original topic,
I have posted on a few threads already (a quick search should churn them up). Belts are definitely something teams can do, but as stated above, tension is key with them. We used kevlar reinforced belts which basically eliminated "stretching" so we did not need an active way of adjusting the tension. I would suggest doing a lot of research to make sure they are something you want to consider.
Right now I could not tell you what our plan is for the upcoming season. We are proud we used belts effectively and we will see what the game is before we commit to using them again.
Let me know if you have any more questions.
Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-11-2008, 09:12
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
did 118 use that ajustable v-belt stuff to power form the v6 to the swerve drive wheels
Brandon could you post or pm me were you got you belts
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 17-11-2008, 11:12
AKA: Sean
I'm almost positive that 125 purchased there belts from sdp-si.com They have a great selection and some helpful calculators as well.
Mentor 2415
Unread 17-11-2008, 14:44
run the trap!!!
Team Role: Human Player
The statement that belts cannot handle high torque is false. Lots of machines like large mills and motorcycles use belts without any trouble.
The problem with belts is that they are not good at changing directions quickly. Often, when they go from forwards to reverse very quickly, (as in a FIRST robot) they skip teeth or go flying off.
Notice how 118 only needs to drive their wheels 1 direction?
-Philip J. Fry
Unread 17-11-2008, 17:02
We ordered our belts from http://www.sdp-si.com/. They are a reliable source, equivalent to any kind of supplier. They offer a large variety of sizes, lengths, and materials in both the pulley and the actual belt.
Timing belts kajeevan General Forum 6 13-08-2008 13:59
Join timing belts GMAdan Technical Discussion 5 19-04-2007 16:03
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
