Go to Post Adding more weight doesn't make the challenge any easier, it just makes the robots heavier. - Sean Schuff [more]
  #121   Spotlight this post!
Unread 17-11-2008, 11:12
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
Re: New Speed Controller Announced
Originally Posted by ajlapp View Post
Any chance you can supply a complete solid model of the housing? The iges file imports as a shell which can be troublesome to work with.
Is Luminary aware that it is common for teams to purchase many of these during a season? Teams that construct 2 complete robots may purchase 10-15 of these in a single season!
If these are purchased for non-FIRST applications will their full potential be available?
Thanks.
Unfortunately, I cannot supply a complete solid model at this time.
As for non-FRC apps, the full "raw potential" of the Jaguar is available. The short version of the story: you need CAN to enable Jaguar's non-FRC2009 features and we purposely stunted the Jaguar's CAN API development until after FRC2009 (for the purpose of FRC2009). So, the full potential is available, but the method to unleash these features (CAN) is purposely not yet so easy to use that a marketer like me could do it.
(Did I just cut myself down?)
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
  #122   Spotlight this post!
Unread 17-11-2008, 11:54
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Originally Posted by Richard McClellan View Post
The specifications table states that the Fan On temperature is 42 degrees Celcius and the Fan Off temperature is 38 degrees Celcius
The last Q&A question states:
So my question is, does the fan come on when you start running a motor, or when the temperature hits 42 degrees, or both?
The fan turns on when you start running the motor.
The fan turns off when you stop the motor, 10 seconds pass, and the temperature is 38 degrees C or less.
The intent of this is to avoid wasting your battery at the start of a match. The fan (ebmpapst 412 FH) is spec'd at 0.8 W (66 mA 12 V). By extension, the fans of 8 motor controllers draw more than half an amp waiting for the match to start. Yeah, nothing compared to what the motors draw during the match, but little bit helps, and it was simple enough to implement (a MOSFET and some software).
  #123   Spotlight this post!
Unread 17-11-2008, 11:56
AKA: Scott McMahon
According to the Getting Started guide, it is recommended to have 1/2" of empty space on the left and right side of each Jaguar speed controller. If you were to mount two Jaguars with their sides adjacent to each other, can this 1/2" space overlap, or would you need a total of 1" of space in between the two?
Yes, the 1/2" space can overlap.
  #124   Spotlight this post!
Unread 17-11-2008, 12:22
AKA: Scott McMahon
The fact that a an overcurrent on a jaguar causes it to shutdown until a neutral signal is given scares me.
I've checked on this and the Jaguar does not require a neutral signal following a fault (anymore). The original prototype firmware of Jaguar did, but it was fixed a long time ago. The documentation is incorrect and will be changed shortly.
With the victors, I've never seen one overcurrent in recent times. Heck, I've never had a 40 amp breaker pop during a match on any team I've been on in recent times.
Not surprising. A presentation at the 2008 FIRST Robotics Conference by Al Skierkiewicz says the breakers can function for a few seconds with up to 600% over current and almost 10 seconds up to 200% over current. See http://first.wpi.edu/Images/CMS/Firs...ierkiewicz.ppt
In testing at Luminary Micro, we drove a 150 lb robot rather mercilessly and didn't experience an over current fault. The only time an over current fault was generated was when the wheel of the robot was locked.
  #125   Spotlight this post!
Unread 17-11-2008, 17:04
AKA: Scott Emley
Please note that we have just updated the Getting Started Guide (rev JAGUAR-GSG-02) at http://www.luminarymicro.com/jaguar.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
  #126   Spotlight this post!
Unread 17-11-2008, 17:24
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Maybe this isn't the same thing that you were talking about, but the just-posted Getting Started guide says that when the Jaguar is reset (because of a tripped breaker), you need to return it to neutral before it will accept incoming PWM signals. This seems like AdamHeard's comment is therefore still valid.
  #127   Spotlight this post!
Unread 17-11-2008, 18:00
AKA: Scott McMahon
The FAQ is (still) wrong and will be updated shortly.
  #128   Spotlight this post!
Unread 18-11-2008, 18:01
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Can someone confirm that the jaguar sold by Digikey is in fact the ones we can order already in advance for this year's game? I couldnt find the post of the vendors, if I recall, that either offered them or had them at a discount.
Sorry, dont want to read 100+ posts to maybe find the info here.
  #129   Spotlight this post!
Unread 18-11-2008, 18:13
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here you go. http://sales.digikey.com/dkes/FirstR...ompetition.asp
From post #102. It took me two minutes to find it.
  #130   Spotlight this post!
Unread 18-11-2008, 18:40
AKA: Scott Emley
Please note that we have just updated the Getting Started Guide (rev JAGUAR-GSG-04) at http://www.luminarymicro.com/jaguar to reflect this change.
Sorry for any confusion.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
  #131   Spotlight this post!
Unread 19-11-2008, 00:26
waialua359's Avatar
AKA: Glenn
thanks for saving me the trouble.
  #132   Spotlight this post!
Unread 19-11-2008, 01:00
billbo911's Avatar
You are quite welcome
Mahalo
  #133   Spotlight this post!
Unread 04-12-2008, 09:18
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Does any one know if there is a way to monitor the state of the limit switches for debugging purposes? Maybe by adding a LED in series with the Limit switches or something?
-Oris-
  #134   Spotlight this post!
Unread 04-12-2008, 09:35
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
This information is available on the data sheet available from Luminary:
http://www.luminarymicro.com/products/rdk-bdc.html
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
  #135   Spotlight this post!
Unread 04-12-2008, 10:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
-Oris-
Your best bet is to get some double pole microswitches and wire one pole into the Jag, and the second pole into a digital sidecar or something else. When we have access to the CAN interface, the state will be monitored from there, but that's not happening this year.
New Vex Microcontroller announced Brandon Martus General Forum 19 07-05-2009 16:00
FRC Robot Controller/Speed Controller RoarRoar Control System 3 17-01-2008 10:41
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
New Special Edition GameBoy Announced Joe Matt Chit-Chat 12 13-01-2003 21:35
