Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 18-11-2008, 19:07
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
pic: Latest on wood-coast chassis
Unread 18-11-2008, 19:08
tim_reiher's Avatar
tim_reiher tim_reiher is offline
Cornell 2014!
FRC #0571 (Team Paragon)
tim_reiher is just really nicetim_reiher is just really nicetim_reiher is just really nicetim_reiher is just really nicetim_reiher is just really nice
Send a message via AIM to tim_reiher
Re: pic: Latest on wood-coast chassis
Wow... that's like a super awesome nerf gun on steroids...
How far do those pool noodles go?
Today's words of advice- "don't try to broach through your finger". Nothing good can really come of it.
Check out our really new website!
Unread 18-11-2008, 19:44
Bertman's Avatar
about 30 feet
Unread 18-11-2008, 19:51
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
haha, thats really cool. Are the noodles fed by pnumatics? yall will sure be ready for a pool noodle game this year
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 18-11-2008, 20:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
This is cool! What type of gear are you using on the outside perimeter of the turret? Can I see a closer picture of that part?
Unread 18-11-2008, 21:18
Bertman's Avatar
it is the flywheel from a Chevy pick up driven by a window motor
Unread 18-11-2008, 21:24
Bertman's Avatar
By the way. The bare chassis is red oak and weighs in at 7 pounds 6 ounces. It is six wheel drive.
Unread 18-11-2008, 21:35
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How is the wood holding up under usage. Have you tested its strength in impacts with other things such as robots and walls? Also how are the bearing holes holding up? Have they started to enlarge?
Mentor 2415
Is it bare oak or did you guys make a composite of some sort? Either way, looks great.
Unread 18-11-2008, 22:13
run the trap!!!
Team Role: Human Player
Is it really the same pitch? Thats very resourceful. How much does it way? Most flywheels aren't light...
-Philip J. Fry
Unread 18-11-2008, 23:18
LeadCoreWarrior's Avatar
LeadCoreWarrior LeadCoreWarrior is offline
OCD Wire Monger/Project Manager
AKA: Gabe Ochoa
FRC #0418 (LASA Robotics/Purple Haze)
Team Role: Electrical
LeadCoreWarrior is an unknown quantity at this point
Send a message via AIM to LeadCoreWarrior
Pneumatics were not powerful enough and we found that the time it took to regain the compressed air that was lost was not fast enough. There are wheels midway up on the barrel that provide the propulsion. The pneumatics just provide the trigger to push the noodles forward into the spinning wheels.
2008 Overdrive Operator
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction." ~Albert Einstein
Unread 19-11-2008, 08:30
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
it might be a flex plate from an automatic, it holds the ring gear and is sheet metal rather than a heavy flywheel from a manual transmission set-up.
mike d
See Ya
Unread 19-11-2008, 12:23
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
I love the foam dart shooter--a great idea for a demo bot!
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 19-11-2008, 13:55
Rick's Avatar
Rick Rick is online now
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
It drives well, seems to be durable and has a rotating turrent which fires 12" long sections of swimming noodles as fast as you can pull the trigger. Great for indoor demos around small children.
I love shooting small children with pool noodles.
Like Aquidneck Island Robotics on Facebook!
Unread 19-11-2008, 21:47
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Story time!
assigned to create a demo robot by our coach, we decided to make an awesome pool noodle shooter. Due to grade deadlines, we had to abandon certain features such as an auto feeding magazine that could store more pool noodles, a tilt, and full 360 degree rotation capabilities. these may be added on by later classes of LASA Robotics seniors, and Twiggy, and its fantastic weapon (project racecar), will continue to evolve into a fantastic demo robot!
However, that dosen't make it the most awesome thing ever!!! the gravity fed hopper, pnumatic firing pin, and flywheels make for an impressive rapid fire.This thing makes a tremendous noise when spinning, and loves to shred pool noddles who don't behave!
The flywheels are actually zip tied to the aluminum Andy mark hubs, which in turn are JB welded to the output pinions of the bosh drill motors. true story.
As for the chassis and drive train, dewalt drills (including their original motors) power each side. This thing is pretty hefty, able to power it's way over dirt humps, up handicap ramps, through stacks of plastic crates, and can certainly try to bash its way though walls unharmed. I even managed to hop a curb with it.
hope yall enjoyed our project! we are really proud of it!
pic: Wood as an David Brinza Extra Discussion 4 08-04-2006 19:29
pic: 1346 - Wood is Good dtengineering Robot Showcase 21 14-02-2006 02:15
Input On Steel chassis w/wood inset Henry_Mareck Technical Discussion 36 20-12-2005 14:52
Space Ghost Coast to Coast to DVD Nov 18th!! D.J. Fluck Chit-Chat 7 07-11-2003 18:57
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
