Go to Post [on practice robots:] Twice the work and twice the practice building seem to equal twice the experience so far. - MrBasse [more]
Unread 19-11-2008, 12:46
Early Bird Control System
Unread 19-11-2008, 12:47
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: pic: Early Bird Control System
So they are, in fact, having us use those huge DB-37 cables to connect the DSCs to the cRIO.
Hopefully we will be allowed to replace them with ribbon cables.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 19-11-2008, 13:06
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
I like seeing the 2 digital sidecars. Even though most teams won't need more than 1.
Unread 19-11-2008, 13:17
Gdeaver Gdeaver is offline
FRC #1640
In the past I've been a little critical of First for not providing value for the fees. I with draw my judgement. Dam those Jags are big!
Unread 19-11-2008, 13:31
It even includes the Wago Tool!
There is another photo pending that shows the Victor and Jaguar side-by-side. Those Jags are massive!
It seems to just be a fine blade. If we use a close match are there potential problems we should be wary of?
I just imagine having only one Waco tool means it will immediately be misplaced.
Unread 19-11-2008, 13:53
There are heretics among us who claim that The Wago Tool is nothing but a screwdriver. Heed not their false claims. Observe how The Wago Tool handles itself during these outbursts: The Wago Tool allows their fallacies to flow past itself unheeded, for it is above such petty insults. The Wago Tool holds within itself true knowledge of its function, which no external forces may sully.
One may attempt to use lesser tools, but Hark! Thou must still be true to the spirit of The Wago Tool. Insert the tool fully, in a graceful glide. Once sheathed in its Wago Connector Home, remove thy hand from the tool and insert the stripped wire. Gently remove the tool, and smartly tug the wire to verify your success.
Unread 19-11-2008, 14:07
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
that is no WOGO tool guys sorry but if you look the WOGO web site it says the WOGO tool has a "Partially insulated shaft makes this tool an optimal choice for connecting terminal blocks"
link-http://www.wago.us/products/2453.htm
looks nice but man i hope they give us 5 more lbs
and the jags are shiny and nice but they big and i still have questions on there air flow
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 19-11-2008, 14:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
I'm pretty sure those "Wago Tools" serve a double life as "Wago promotional flathead mini-screwdrivers their sales reps hand out to potential customers", of which I have several in my desk at work.
I don't think the ground will open up and swallow you whole if you use a slightly "irregular" mini screwdriver to get the job done.
Umm Errr...
That is a large number of of really big components to fit in a small space.
1139 Alumni
Unread 19-11-2008, 14:11
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Are the joysticks comfortable (in ergonomic terms) & interchangable, or do we have two right-handed sticks again?
I'm not familiar with that brand.
Unread 19-11-2008, 14:17
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Yes they are right and left handed. Can't wait to use these things! (I am a Logitech fan boy)
http://www.logitech.com/index.cfm/ga...s/302&cl=us,en
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 19-11-2008, 14:38
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Nobody said they had to fit in a small space. Yet. We'll see in January.
Hi!
Unread 19-11-2008, 14:42
Lowfategg's Avatar
AKA: Tyler Moser
I am sure we can smash it in a very small space.
We might have to think outside of the box...
Unread 19-11-2008, 14:45
Realize that a lot of the things pictured do not go on the robot. Also, many of the components are optional (pending the official rules).
Early Shipment of the New Control System EricVanWyk FRC Control System 3 05-11-2008 13:51
**FIRST EMAIL**/ FRC 2009 Control System Early Release Update dlavery FIRST E-Mail Blast Archive 12 15-10-2008 19:30
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
pic: Team 116 Modular Control System dlavery Robot Showcase 42 21-10-2007 11:15
pic: FIRST's New field control system Greg Needel Extra Discussion 22 12-01-2007 09:23
