Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
Unread 16-11-2008, 21:14
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to behold
off center 6WD help
so my team is letting me start my own drive train project and i decided to try to build a 6 wheel off center drive. can anyone post some specs, tips and how to's so everything goes more smoothly?
Learn something, Know Something, Do something
Unread 16-11-2008, 21:22
Re: off center 6WD help
6WD "drop center" or "rocker" isn't too hard. The main thing is to get the drop right and the CG right.
The drop shouldn't be very much. 1/16" -1/4" is sort of the "standard" range, with the majority being around 1/8"-3/16". Occasionally, someone has more.
CG is kind of important. You don't really want it dead center, surprisingly enough. This will aggravate the rock, causing undesirable results. Somewhat forward/aft seems to work much better.
Other than that, try different combinations of wheels. Sometimes, that can help performance.
Unread 16-11-2008, 21:50
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
By 'off center' do you mean the center wheels further outboard/inboard or do you mean the center wheels further forward/back?
EricH is exactly right but I should point out that when he states 'dead center' that really means the CG being directly over the lowered wheels (assuming the lowered wheels are not in the center, 'forward/back'). The closer (forward/back) to your lowered wheels and the higher the CG is the more it will affect the rocking action of the robot.
___________________
- Tennyson, Ulysses
Unread 16-11-2008, 22:28
lenny8's Avatar
Aww Yea
AKA: L-Deezy
by off center i mean drop the center as said by Eric.
Unread 19-11-2008, 16:03
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
Question Re: off center 6WD help
I have a question related to 6 Wheel Drive.
It is generic for all 6 wheels.
What are the possible ways to drive the wheels through the shaft?
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 19-11-2008, 16:40
Live axle? Key and hex are pretty much your options.
Key: cut a slot in the axle. Cut the same size slot in the wheel hub. Put a small piece of metal (the key) into the slot in the axle and slide the wheel on.
Hex: Cut the axle so it's hexagonal. Cut (technically, broach) the inside of the wheel hub into a matching hex pattern and slide them together. [Edit] This could work with other shapes, though hex is the most common.[/Edit]
Secure the one you use so it won't slide along the axle.
There is also dead axle, where the axle doesn't move relative to the wheel. That has its own tricks.
Unread 19-11-2008, 17:36
CraigHickman
Posts: n/a
A drop between 1/8th and 1/10th of an inch will do you plenty of good, assuming you take a bit of time to see that your superstructure is remotely balanced. Otherwise, you might be better off to shift the center wheel underneath the center of mass for your robot (if you need to find this, CAD is your best bet).
Oh, also: Post pictures once you make it! We all like to ogle them shiny robots.
Unread 19-11-2008, 18:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
As Eric mentioned, this is actually NOT what you typically want to do. If the CG is directly above the center wheels the robot will tend to rock far more frequently than if the CG is located in front of or behind the center pair.
Unread 19-11-2008, 19:18
CraigHickman
Posts: n/a
Weight distribution is like Eggs for Breakfast: Some people pay more attention to detail than others. I personally like to have my weight centered when I build a 6 wheel, and will shift the middle wheels to match. If your robot is actually "rocking" to the point where it's affecting your steering, you may have dropped your center wheel too much. It really doesn't take much, if ANY, drop to allow a 6 wheel to turn without bouncing.
EDIT: Example of drop not being entirely necessary if you do your design work right: Team 25. Those crazy folks haven't dropped a wheel in years, and they don't bounce...
Unread 19-11-2008, 19:26
AdamHeard's Avatar
Lead Mentor
I think it's insulting to say Eric's experience with a 6 wheel had no attention to detail. He learned his 6 wheels with 330, which has had some pretty nice ones the last few years.
I'll second his recommendation not to put the weight over the center wheels, you'll get a much better performing 6 wheel.
As for team 25, yes their bases work, and yes they don't drop the center wheel. But I'm pretty sure I've seen them bounce like crazy while turning before.
Unread 19-11-2008, 19:35
Think of it this way:
Your center of gravity is right above your middle "dropped" wheel. (I don't much care how far up it is; that's your choice.) So far, so good, right? Now, you accelerate forwards. Your CG is a little bit slower than the drive frame to respond (law of inertia--it takes a little bit to get the motion up there), and you rock onto your back wheels. You'll stay there until you stop. When you stop (accelerating backwards), the CG again takes a bit to figure out, "Oh, I need to stop!" and goes into the front section. You rock onto your front wheels. The rebound sends you onto your back wheels. Repeat until the CG stops moving. But...
You may be moving again already, or you may be trying to acquire a game piece. This prevents the CG from settling. Worse, the CG bouncing around could potentially throw off your attempts to pick up the piece. In a typical game where speed in acquiring and unloading is important, this can adversely affect scoring potential.
Having the CG on one end or the other WILL NOT stop the rock. It will, however, make it settle much faster.
It's like a seesaw-- sure you can balance it on the middle. Give it a light tap, and it leaves the middle. So you have to work to return it to level. Add a little more board to one side to keep one end down, and you don't have to work as hard to return it.
Oh, and you can easily have a 6WD that turns without bouncing or drop. Stick omni wheels on one end.
Unread 19-11-2008, 19:39
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
i second that motion,
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 20-11-2008, 00:51
CraigHickman
Posts: n/a
Meant that in no way to be insulting, I'm truly sorry if it came across that way. It was more meant as a statement towards myself: I've always been a little bit lackadaisical when it came to mechanical principals, physics, math, and all that (hence why I'm a sociology major! gasp!), but center of mass has been one of the few that I actually spend time on.
Though hey, the idea of Omni's is also an awesome one. No need for drop, no need for rocking, and you can put your weight in the middle. It's like getting cake, and eating it too!
Unread 20-11-2008, 01:12
AdamHeard's Avatar
Lead Mentor
But while eating your cake, you're more easily spun.
It can be desirable in some cases, but I wouldn't do it.
Unread 20-11-2008, 13:31
lenny8's Avatar
Aww Yea
AKA: L-Deezy
the spining factor is why i dont want omnis. our team has had omnis almost every year ( excluing rookie year and 2008 * sliders and mechs*)
help with 6wd chassie.. Magic General Forum 7 29-03-2008 14:27
Toggle Motor On & Off Help..... programmr Programming 1 16-02-2008 11:15
Off-season help Setsanto 3D Animation and Competition 12 24-02-2007 17:26
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Off Center Bearings Rickertsen2 Kit & Additional Hardware 2 09-01-2003 22:58
