Go to Post This year may be one of the first years where there is a drastic difference in Regional level and Championship level strategies that drive robot design. - tim-tim [more]
Unread 19-11-2008, 22:40
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: gear ratio
Originally Posted by Sam2197 View Post
one of our mentors and i cant seem to agree on this subject. say i have a 12:1 gear ratio for a gearbox. is that for every 12 revolutions of the motor the output is 1 revolution. or for every 1 revolution of the motor its twelve revolutions as an output
Good question.
A 12:1 ratio for a gearbox is such that for every 12 revolutions of the input motor, there is 1 revolution of the output shaft.
Andy B.
Unread 19-11-2008, 22:44
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
Re: gear ratio
thanks for the help. im sure this is an easy thing to get confused
Unread 19-11-2008, 23:00
JM987's Avatar
JM987 JM987 is offline
High Rollers
AKA: Josh Mauro
FRC #0987 (High Rollers)
Team Role: Driver
JM987 has a spectacular aura aboutJM987 has a spectacular aura aboutJM987 has a spectacular aura about
Send a message via Yahoo to JM987
Re: gear ratio
which would give you a looow speed, but high torque
Check Out Our Website!
HERE!
- 2009 Las Vegas Regional Winners (thanks to 1622 and 1013)
- 2009 Las Vegas Regional Chairman's Award Winner
- 2008 IRI Winners (thanks to 330, 67, and 68)
- 2008 Archimedes Division Finalists
- 2008 Las Vegas Regional Chairman's Award Winner
- 2008 Las Vegas Regional Winners (thanks to 39 and 1013)
- 2008 San Diego Regional Finalists
- 2007 FRC World Champions (Atlanta thanks to 190 and 177)
- 2007 Newton Division Winner
- 2006 Las Vegas Regional Winner
- 2005 Las Vegas Regional Winner
Unread 19-11-2008, 23:14
NickE's Avatar
NickE NickE is offline
_
Re: gear ratio
This depends on what motor is used, and what the application is. For example, a 12:1 reduction used with CIM motors would be fast if used for an arm rotation, but slow for a drivetrain.
Unread 20-11-2008, 09:16
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: gear ratio
As an addition to the original post:
If you ever see a reduction given in decimal format (e.g. the 2008 KOP's were 0.0784), THAT is where the output shaft rotates 0.0784 times per 1 revolution of the input (output:input). Car transmissions usually show reductions in this manner. This particular number (0.0784) was calculated by (14/50)*(14/50), where each 14-tooth gear is the input and each 50-tooth gear is the output in their respective stages. Also note what the reciprocal of this number is ( 1 / 0.0784 = 12.75), but to flip the decimal like that you also 'flip' the which side is the output and which side is the input, hence (12.75 : 1) is (input : output).
Whoever lost that argument was probably headed in the right direction but confused about the nomeclature, hence the argument kept going. Durn those kinds of arguments...
GitHub
Unread 20-11-2008, 09:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: gear ratio
When did this start? I must have missed it.
All the car transmission gear ratios I've seen are expressed as the number of turns of the input shaft : one turn of the output shaft. For an overdrive transmission, the overdrive ratio is expressed as a decimal because the output shaft turns faster than the input shaft.
(I read Hot Rod, not Motor Trend, maybe they do things differently?)
Unread 20-11-2008, 10:08
JesseK's Avatar
FRC #1885 (ILITE)
Red face Re: gear ratio
The decimal format is just the number itself, e.g. 0.0784 and not 0.0784:1.
I'll try to explain the reasoning so the OP doesn't get further confused... This stems from my street racing days back in college. Some of the guys were gearbox junkies and tuned their transmissions for lower top speed with ridiculous acceleration through a set RPM range known as a 'power band'. When they would talk about shortening a gear, this was the number they were messing with. It was always less than one, and it represented the reduction from the engine output to the shift stage rather than from one shift stage to the next (which is also sometimes seen). This allowed them to figure out if their cars were still in an 'optimal' power band for each gear after they made a modification to an engine component (which may have shifted the power band to a higher or lower RPM range). This tweaking is similar to the FRC electric motor curves vs the loads we put on the motors. It makes sense to me because the higher the number, the faster the output shaft spins.
I guess I just assumed this verbage can be used for all transmissions since you see that same decimal format used in almost every available FRC calculator. Maybe I was wrong.
GitHub
motor/gear ratio starsROBOTICS Motors 5 24-03-2008 10:02
Last Year's Gear Ratio AndyB Technical Discussion 4 11-11-2007 01:17
Transmission gear ratio MASherry Technical Discussion 6 13-01-2005 10:32
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
