| My encoders let me drive straight to you. |
Shifting Two Anymarks with One Pistion
As you all know, weight is a BIG problem, so much so we decided to go with an off board compressor. Witch lead us on a never ending search for ways to be more efficient. I know a lot of other teams are on in the same boat so we are more than happy to share the knowledge, GP!
http://www.youtube.com/watch?v=ZEn76mg9wx4 pics - http://picasaweb.google.com/john.h.8...gTransmissons# |
Re: Shifting Two Anymarks with One Pistion
Very nice! Innovation is always good to see, especially on the small details! (that means someone other than me is focusing on the details, hurrah!)
Did you use a piston with twice the stroke length?
Looks really nice! |
How did you calculate the distance??? Guess and Check or with CAD.
That looks like a 1" throw cylinder.... wouldn't that be using about the same amount of air as two 1/2" throws plumbed together to one solenoid?
Thatīs what i was thinking. I guess you save the weight of an extra solenoid.
#7
It would weigh less than two cylinders probably (Depending on the linkage weight), but I don't imagine it would reduce air consumption like they claim. |
#9
... it must be late... |
#10
Team 45 was the first I know of to do this, in 2003.
#11
you should check out and see what the total weight of this system vs. two 1/2" stroke cylinders would be. there might not be much weight savings - the small cyliners are pretty light.
Also, you can control them both from one solenoid (which is actually a good design approach so you know both transmissions are shifting at the same time). You might also be cautious - it is not legal to modify the pneumatic cylinders, and some inspectors might be concerned about the modifications you have made. |
#12
48 also did this in 2003 on our 45-inspired dog-shifter design. We also added failsafe springs to force and keep the shifters in gear in the event of a pneumatic system failure.
#13
Simbotics did this last year.
#14
Guess & Check
#15
| Shifting with easyC | Erics626 | Programming | 1 | 24-01-2006 18:58 |
| One or Two Wheel Shooter | Nitroxextreme | Technical Discussion | 6 | 14-01-2006 01:10 |
| [ECDU]:one or two | Michael Leicht | FIRST-related Organizations | 16 | 09-12-2004 07:23 |
| one control stick or two? | 346operator | Technical Discussion | 24 | 12-08-2004 09:59 |
| Control system with one joystick(or two) | CharlieWilken | Technical Discussion | 3 | 04-02-2002 09:20 |
