Re: Shifting Two Anymarks with One Pistion
... it must be late... |
Team 45 was the first I know of to do this, in 2003.
you should check out and see what the total weight of this system vs. two 1/2" stroke cylinders would be. there might not be much weight savings - the small cyliners are pretty light.
Also, you can control them both from one solenoid (which is actually a good design approach so you know both transmissions are shifting at the same time). You might also be cautious - it is not legal to modify the pneumatic cylinders, and some inspectors might be concerned about the modifications you have made. |
48 also did this in 2003 on our 45-inspired dog-shifter design. We also added failsafe springs to force and keep the shifters in gear in the event of a pneumatic system failure.
Simbotics did this last year.
| Shifting with easyC | Erics626 | Programming | 1 | 24-01-2006 18:58 |
| One or Two Wheel Shooter | Nitroxextreme | Technical Discussion | 6 | 14-01-2006 01:10 |
| [ECDU]:one or two | Michael Leicht | FIRST-related Organizations | 16 | 09-12-2004 07:23 |
| one control stick or two? | 346operator | Technical Discussion | 24 | 12-08-2004 09:59 |
| Control system with one joystick(or two) | CharlieWilken | Technical Discussion | 3 | 04-02-2002 09:20 |
