Go to Post We can be equal, but not truly the same. - Molten [more]
Unread 20-11-2008, 10:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: gear ratio
Originally Posted by Sam2197 View Post
so which would be faster for a drivetrain a 12:1 or a 9:1
A higher gear ratio means the motor has to turn more times to get the wheels to move the same distance. So, a higher gear ratio slows down the robot more.
The lower ratio (9:1) will give a faster moving robot.
motor/gear ratio starsROBOTICS Motors 5 24-03-2008 10:02
Last Year's Gear Ratio AndyB Technical Discussion 4 11-11-2007 01:17
Transmission gear ratio MASherry Technical Discussion 6 13-01-2005 10:32
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
