Re: gear ratio
Does anyone have some actual numbers of how fast their robot managed to go as a percentage of the max unloaded motor RPM? I mean as-built with gearbox loss, etc. I'm not interested in feet/sec. figures. I was just wondering if something like 80% was realistic.
Re: gear ratio
I seem to recall from my lurking there being a spreadsheet floating around that calculates acceleration as well as top speed for FRC bots... Am I mistaken? Anyone know where this tool is? |
Re: gear ratio
It's pretty close. 968 did a test of actual ground speed vs calculated theoretical speed of our 2008 robot. The actual speed was approximately 80% of the no load 100% efficiency speed.
Re: gear ratio
Was that calculated from the ~5500 free speed CIM RPM ? Or were you assuming some sort of amperage being pulled?
Re: gear ratio
Which brings me to another silly technical point. Since the CIM is drawing current it has some non-zero input power, even at no-load. However, since there isn't a load output from the shaft, it has zero output power. So the motor's efficiency at no-load is actually 0%, not 100%. |
Re: gear ratio
As to the second point, I meant 100% efficiency as in zero frictional losses in the drivetrain, not 100% motor efficiency. |
| motor/gear ratio | starsROBOTICS | Motors | 5 | 24-03-2008 10:02 |
| Last Year's Gear Ratio | AndyB | Technical Discussion | 4 | 11-11-2007 01:17 |
| Transmission gear ratio | MASherry | Technical Discussion | 6 | 13-01-2005 10:32 |
| Helical Gears Gear Ratio | Joe P | Technical Discussion | 11 | 23-01-2003 22:55 |
| Gear Ratio Doesn't Matter | Paul Copioli | Technical Discussion | 2 | 27-09-2001 08:18 |
