Go to Post Gears will win matches. Climbing will win events. Fuel will win championships. - Taylor [more]
Unread 20-11-2008, 16:40
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
Re: off center 6WD help
Oh, and you can easily have a 6WD that turns without bouncing or drop. Stick omni wheels on one end.
Eric mentioned omni wheels. Just thinking aloud here...
Should omni wheels be on the end where CG is greater or less than the other end? The end that has a greater CG would remain on the ground for most of time where as the end with less CG. So the end with omni wheels will help in turning and thus should be on the end with a larger CG.
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 20-11-2008, 16:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
When using omniwheels, you'd typically eliminate the "rock" from your 6WD -- and so both ends are on the ground at all times.
Assuming that you have four traction wheels and two omniwheels, you'll want for your center of gravity to live above the traction wheels, not the omniwheels. Increasing the total percentage of the robot's weight acting through the traction wheels increases your tractive force compared to placing it over typical omniwheels because the omniwheels have a lower coefficient of friction.
--Madison--
...down at the Ozdust!
Unread 21-11-2008, 10:09
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Not necessarily ... especially on carpet - the edges of the rolling elements on the omni wheels could "dig in" to the carpet more and actually give you increased traction for "driven" omni wheels. Lateral/turning, of course, is another story completely ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
help with 6wd chassie.. Magic General Forum 7 29-03-2008 14:27
Toggle Motor On & Off Help..... programmr Programming 1 16-02-2008 11:15
Off-season help Setsanto 3D Animation and Competition 12 24-02-2007 17:26
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Off Center Bearings Rickertsen2 Kit & Additional Hardware 2 09-01-2003 22:58
