Go to Post I need someone to kick me out...unfortunately that would have to be me... - Mark McLeod [more]
Unread 20-11-2008, 14:37
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: off center 6WD help
Check out the .step files on my site near the bottom of the page.
Universal Chassis
This chassis has many of the features you're interested in. Just looking at the cad models may give you some inspiration for how to design your own custom version. Good luck.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 20-11-2008, 16:40
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
Oh, and you can easily have a 6WD that turns without bouncing or drop. Stick omni wheels on one end.
Eric mentioned omni wheels. Just thinking aloud here...
Should omni wheels be on the end where CG is greater or less than the other end? The end that has a greater CG would remain on the ground for most of time where as the end with less CG. So the end with omni wheels will help in turning and thus should be on the end with a larger CG.
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 20-11-2008, 16:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
When using omniwheels, you'd typically eliminate the "rock" from your 6WD -- and so both ends are on the ground at all times.
Assuming that you have four traction wheels and two omniwheels, you'll want for your center of gravity to live above the traction wheels, not the omniwheels. Increasing the total percentage of the robot's weight acting through the traction wheels increases your tractive force compared to placing it over typical omniwheels because the omniwheels have a lower coefficient of friction.
--Madison--
...down at the Ozdust!
Unread 20-11-2008, 17:02
joshy1323 joshy1323 is offline
AKA: josh anderson
FRC #1323 (madtown robotics)
joshy1323 will become famous soon enoughjoshy1323 will become famous soon enough
in 2006 my team used 6wheel drive with no omni and no lowered center wheel and we learned that when turning our robot bounced around too much. in 2007 we again used a 6wheel with no omni but we did lower the center wheel. in that robot our weight was dispersed outwards horizontally and our robot didnt have any rocking or bouncing problem. however, it turned slowly because the weight was too far from the center of gravity. in 2008 we used the same setup as 2007 but this time we put all our weight as close to the center as possible. we still didnt bounce when turning and we turned much faster, but we did have issues with too much rocking. this year we plan to use 6wheels that are all the same elevation but this time we will use omni for the front 2. i saw someones post that said this will make us too easily turnable. with a 6 wheel drive with a lowered center and no omni the force of static friction is only present on 4 wheels at a time because 2 wheels will always be slightly off the ground. that means we should have the same static friction ratio with a level elevation wheel setup and 2 omni wheels in the front.
----1323 josh
Unread 20-11-2008, 19:32
NickE's Avatar
NickE NickE is offline
_
On Team 254's 2008 robot, there was almost no weight forward of the center wheels, due to the open front on our frame. It only really went on the front wheels at all when rapidly stopping or rapidly reversing. We had good performance, and almost never had to change tread on the front wheels.
Unread 21-11-2008, 09:29
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud of
Thumbs up Re: off center 6WD help
Thanks everyone for all the help so far.
keep it coming.
Learn something, Know Something, Do something
Unread 21-11-2008, 10:09
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Not necessarily ... especially on carpet - the edges of the rolling elements on the omni wheels could "dig in" to the carpet more and actually give you increased traction for "driven" omni wheels. Lateral/turning, of course, is another story completely ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
help with 6wd chassie.. Magic General Forum 7 29-03-2008 14:27
Toggle Motor On & Off Help..... programmr Programming 1 16-02-2008 11:15
Off-season help Setsanto 3D Animation and Competition 12 24-02-2007 17:26
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Off Center Bearings Rickertsen2 Kit & Additional Hardware 2 09-01-2003 22:58
