Go to Post If you're in the Chairman's Award just to win the Chairman's Award, you're doing it for all the wrong reasons. The award is there as a goal to strive for, but it shouldn't be the reason why you conduct yourself and reach out to your community and beyond the way you do. - Lil' Lavery [more]
Unread 20-11-2008, 22:06
CraigHickman
Posts: n/a
Re: pic: Night & Day
I have to say, I'm not too thrilled about having to pack these suckers into our robot... In the past, electronics have already been a squeeze. We shall see, though.
On the plus side, it seems like it will be slightly harder for us to drop shavings and chips onto the H bridge, and fry them! This is good, because high school students seem to have an impressive ability to fry any electronic system you put in front of them...
Unread 20-11-2008, 22:12
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Jaguars and Victos weigh approximately the same. I know from holding them and comparing; there is no noticable difference unless you put it on a very accurate scale.
Unread 20-11-2008, 22:51
Deep Dark's Avatar
Deep Dark Deep Dark is offline
AKA: Dave Woods
FRC #2506 (Saber Robotics)
Deep Dark is on a distinguished road
Send a message via AIM to Deep Dark
I simply cannot get over the size difference. I'm really not a complainer, but having controls aspects adding more weight, and taking up more space, on the robot is not exactly something I am looking forward to. I guess we'll just need to not put as much mechanical stuff on inorder to make weight and size.
Dave Woods
Mechanical Engineer - Rexnord Conveying Equipment (New Product Development)
Alumni - Milwaukee School of Engineering (W-11
May '07 - present: Mentor/Co-Lead - F.R.C. Team 2506 Saber Robotics
May '06 - May '07: Mentor - F.R.C. Team 537 Charger Robotics
May '02 - May '06: Student - F.R.C. Team 537 Charger Robotics
Unread 20-11-2008, 23:31
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
It depends on the limits this year. I'm sure they'll take the new system into consideration when making the rules this season.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 21-11-2008, 00:14
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I have a strong feeling the limits will remain under the size of a standard door. A standard door is 36" wide and you have to leave room for the door itself and the doorstop (the thin slat that sticks out from the jamb on the side opposite the hinges). With bumpers added on each side of the 28" that was the max width last year you are already pushing up very close to that.
I suppose they could add to the length though.
Unread 21-11-2008, 00:28
Joining the 900 Meme Team
FRC #0079
As stated earlier the new Jaguars dont weight that much more than the Victors. Size wise they may be larger but perhaps we will stop seeing the electronics being shoved in wherever they will go. We will just need to be more careful with our designing. With any luck it will FORCE teams to clean up their wiring and electrical boards.
Unread 21-11-2008, 00:33
synth3tk's Avatar
AKA: David Thomas
Oh, my bad. I misread the post. I thought he meant weight limits.
Well, as stated above, plan on cleaning up your electronics nicely this year, and you should be fine.
Unread 21-11-2008, 00:39
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It appears I'm the one that should be apologizing. He mentioned both weight and size, but for some reason I assumed you were talking about size.
Unread 21-11-2008, 02:29
synth3tk's Avatar
AKA: David Thomas
Wow, I guess he did. It's time for me to go to bed.....
Unread 21-11-2008, 06:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'd like to think that 254 and 968 have nicely organized electronics boards and I can say without a doubt that we could not possibly fit jaguars into any of our past 3 robots without redesigning the actual robot itself.
The size of the jaguar is a very real concern for us, regardless of how much better it's performance may or may not be.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-11-2008, 07:10
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
sounds like the poofs and rawc will have a challenge this year, and I am sure they will out do everything previously accomplished.
mike d
See Ya
Unread 21-11-2008, 09:54
NickE's Avatar
NickE NickE is offline
_
That would be on the assumption that we choose to use the jaguars this year.
Unread 21-11-2008, 10:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I imagine we'll see more 3-D layouts for electronics this year. The first layout we'll probably try is an upside-down "T", with the Jaguars on the vertical part.
GitHub
Unread 22-11-2008, 21:46
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
I got our kit today, and i saw the pro and the con of the jaguar
Pro: good performance, SURPRISINGLY LIGHT WEIGHT!!!
Con: looks even bigger in person (at least i think)
Unread 22-11-2008, 21:56
AdamHeard's Avatar
Lead Mentor
Can someone actually weigh the two and post?
A .1lb difference may not be noticeable by holding them, but could easily be an entire pound on the robot.
pic: CRT T-SHIRT Shooter At Night Kyle A Extra Discussion 7 21-09-2006 13:04
pic: Atlanta at Night (cloudy) Joe J. Extra Discussion 7 01-05-2006 21:24
pic: Mayhem Night Crew Tytus Gerrish Extra Discussion 7 11-07-2005 00:55
pic: David Kelly's long night D.J. Fluck Extra Discussion 3 20-03-2005 23:23
pic: 696 - The 1st late night CD47-Bot Extra Discussion 22 17-02-2004 06:45
