Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 21-11-2008, 11:16
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: pic: Mecanum Musings
I like this my team does another comp other than FIRST called BEST and has been looking at how to implement mecanums with the limited kit you are given, I think this might be the solution. Really beautifully simple.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 21-11-2008, 11:33
CraigHickman
Posts: n/a
Originally Posted by M. Mellott View Post
Very interesting design! It's so simple, enough so that almost anyone could make these in a small shop! I'll be really interested to see these in action.
What size wheel would this equate to? Maybe 4" or 4.5" mechanum?
The goal was definitely to have minimal impact on machining resources (gotta save all that complex stuff for the manipulator!), and keep cost down.
The effective diameter is about 4.375. It is a little rough ride, as the design goes, so I'll be doing some incremental changes to address the problem.
Unread 21-11-2008, 11:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
What would happen if you tried to use a smaller hex for the central hub?
Unread 21-11-2008, 12:04
dtengineering's Avatar
AKA: Jason Brett
Nice design! It is apparent that you took practical considerations into account as the primary design factor. There was a recent thread on CD, in contrast, discussing a mecanum wheel that the designer took aesthetic considerations into account as the primary factor... but as a result the wheel needed to be made on a 5 axis CNC mill in his opinion.
I can guess which one is more likely to show up on a robot!
As for the bumpy factor in the ride, you could always (at this cost) build 8 wheels, and attach them in tandem, with one rotated 30 degrees from it's partner... much the same way you can use two omnis to smooth out the ride.
Jason
Unread 21-11-2008, 13:33
Joining the 900 Meme Team
FRC #0079
Jason
I remember that thread, IMHO this wheel looks almost as nice as it. Not as flashy but it has an elegance that certainly makes it beautiful.
Jason, would mounting two of them like that really work? I mean I suppose it would but has anyone ever done it with Mecanums?
Unread 21-11-2008, 22:00
I've driven a platform with doubled AndyMark mecanums, and it works just fine. It almost looks like they were designed to be able to be mounted that way.
Unread 21-11-2008, 22:35
FRC #0079
Ok, thanks, Ive just never seen anyone do that.
Unread 21-11-2008, 13:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
For even less necessary machining, you could not mill out the inside of the hex stock, and instead thread-tap the holes where the counter-sunk screws go in. This makes it a bit heavier, but you wouldn't need a mill to make the wheel.
Then, you could also drill the KOP hub bolt-circle pattern into the side, eliminating the necessity of having to make a key way.
To take this even further, instead of counter-sunk screws you could use half-head-height machine bolts, eliminating the need to create the extra dimple after the initial hole is drilled.
GitHub
Unread 21-11-2008, 13:56
CraigHickman
Posts: n/a
Not sure. Next time I boot my Mac into windows to do some CAD, I'll throw together a different version with smaller hex. But to be honest, I'm not sure I'd feel comfortable making it any smaller. The team I'm mentoring has an affinity for Banebots transmissions, so I think the goal is to keep to wheels that can be direct driven off a BB tranny.
There are definitely many revisions that could be made to seriously reduce machining time, but this is really just a 1.0 wheel. I'm debating changing the milling operation on the hex to be entirely one sided, so the "dishing" of the wheel would be done in a single Mill op. I'll have to do some FEA tests to see how the strength would stack up.
Also, for the rough ride concerns: Once I make the wheel wider, and thus the rollers longer, the wheel actually smooths out a good bit.
Unread 21-11-2008, 14:52
Woah, the assembly for these looks incredibly easy! Great design.
Unread 21-11-2008, 15:13
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Originally Posted by Speedfiend View Post
There are definitely many revisions that could be made to seriously reduce machining time, but this is really just a 1.0 wheel. I'm debating changing the milling operation on the hex to be entirely one sided, so the "dishing" of the wheel would be done in a single Mill op. I'll have to do some FEA tests to see how the strength would stack up...
I think what you have here is just fine. If you're using a CNC mill, the same program would be used for both sides, so there could be time savings there. Another option would be to incorporate a spoke pattern something like our 4" tread wheel design. It might help if you plan on making the wheel wider.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 21-11-2008, 21:23
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
that mecanum looks really good, reminds me alot of the WPI wheel from 2005 except a little smaller. Do you have a view directly from the side so we can see the complete arc of the rollers?
Unread 21-11-2008, 21:46
CraigHickman
Posts: n/a
Sure, let me grab a render real quick. I'll edit this post in a minute with it.
There's two renders here: My 1.0 ultra-cheap design, which is with 6 rollers. It's outer diameter is around 4, 4-5 inches. Next is the 8 roller one, a bit smoother, and a little bit larger with a effective diameter of 6 inches.
Unread 23-11-2008, 18:41
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
You're completely right. My apologies for getting off topic.
How wide do you think the wheel would have to be to give a smooth ride?
Unread 23-11-2008, 19:06
CraigHickman
Posts: n/a
About 3 inches wide, then it's pretty much smooth.
Here's a render of the latest revision. It's little bigger (effective diameter of 8ish inches), and uses more machining resources. to shave weight off.
Once I hit a revision that i feel comfortable putting on a robot, I'll be hosting the CAD for anyone that wants it, with only one rule: if you make it or modify it, you also have to put the CAD up. It's time to bring Open Source to robotics, folks.
pic: vex mecanum 1 psyco_klown Extra Discussion 9 05-05-2008 23:22
Musings from a FIRST Inspector Wayne Doenges General Forum 36 26-02-2008 21:31
pic: Mecanum Prototype 1 Doug G Extra Discussion 8 06-04-2007 21:34
pic: 1" mecanum Tytus Gerrish Extra Discussion 8 04-10-2005 13:44
Sweet Repeat musings........................ skrussel Off-Season Events 3 19-10-2003 23:33
