Re: pic: Mecanum Musings
The effective diameter is about 4.375. It is a little rough ride, as the design goes, so I'll be doing some incremental changes to address the problem. |
What would happen if you tried to use a smaller hex for the central hub?
Nice design! It is apparent that you took practical considerations into account as the primary design factor. There was a recent thread on CD, in contrast, discussing a mecanum wheel that the designer took aesthetic considerations into account as the primary factor... but as a result the wheel needed to be made on a 5 axis CNC mill in his opinion.
I can guess which one is more likely to show up on a robot! As for the bumpy factor in the ride, you could always (at this cost) build 8 wheels, and attach them in tandem, with one rotated 30 degrees from it's partner... much the same way you can use two omnis to smooth out the ride. Jason |
Jason, would mounting two of them like that really work? I mean I suppose it would but has anyone ever done it with Mecanums? |
I've driven a platform with doubled AndyMark mecanums, and it works just fine. It almost looks like they were designed to be able to be mounted that way.
Ok, thanks, Ive just never seen anyone do that.
#7
For even less necessary machining, you could not mill out the inside of the hex stock, and instead thread-tap the holes where the counter-sunk screws go in. This makes it a bit heavier, but you wouldn't need a mill to make the wheel.
Then, you could also drill the KOP hub bolt-circle pattern into the side, eliminating the necessity of having to make a key way. To take this even further, instead of counter-sunk screws you could use half-head-height machine bolts, eliminating the need to create the extra dimple after the initial hole is drilled. |
#8
Also, for the rough ride concerns: Once I make the wheel wider, and thus the rollers longer, the wheel actually smooths out a good bit. |
#9
Woah, the assembly for these looks incredibly easy!
Great design. |
#10
that mecanum looks really good, reminds me alot of the WPI wheel from 2005 except a little smaller. Do you have a view directly from the side so we can see the complete arc of the rollers?
#12
There's two renders here: My 1.0 ultra-cheap design, which is with 6 rollers. It's outer diameter is around 4, 4-5 inches. Next is the 8 roller one, a bit smoother, and a little bit larger with a effective diameter of 6 inches. ![]() ![]() Last edited by CraigHickman : 21-11-2008 at 21:50. |
#13
You're completely right. My apologies for getting off topic.
How wide do you think the wheel would have to be to give a smooth ride? |
#14
Here's a render of the latest revision. It's little bigger (effective diameter of 8ish inches), and uses more machining resources. to shave weight off. Once I hit a revision that i feel comfortable putting on a robot, I'll be hosting the CAD for anyone that wants it, with only one rule: if you make it or modify it, you also have to put the CAD up. It's time to bring Open Source to robotics, folks. ![]() |
#15
can you render it with a viewpoint that's much further away, so the view of the side of the wheel is "flat"?
also....open source is nice! we did some this past season, I know we inspired a few teams |
| pic: vex mecanum 1 | psyco_klown | Extra Discussion | 9 | 05-05-2008 23:22 |
| Musings from a FIRST Inspector | Wayne Doenges | General Forum | 36 | 26-02-2008 21:31 |
| pic: Mecanum Prototype 1 | Doug G | Extra Discussion | 8 | 06-04-2007 21:34 |
| pic: 1" mecanum | Tytus Gerrish | Extra Discussion | 8 | 04-10-2005 13:44 |
| Sweet Repeat musings........................ | skrussel | Off-Season Events | 3 | 19-10-2003 23:33 |
