Re: pic: Mecanum Musings
Also, for the rough ride concerns: Once I make the wheel wider, and thus the rollers longer, the wheel actually smooths out a good bit. |
Woah, the assembly for these looks incredibly easy!
Great design. |
that mecanum looks really good, reminds me alot of the WPI wheel from 2005 except a little smaller. Do you have a view directly from the side so we can see the complete arc of the rollers?
There's two renders here: My 1.0 ultra-cheap design, which is with 6 rollers. It's outer diameter is around 4, 4-5 inches. Next is the 8 roller one, a bit smoother, and a little bit larger with a effective diameter of 6 inches. ![]() ![]() Last edited by CraigHickman : 21-11-2008 at 21:50. |
You're completely right. My apologies for getting off topic.
How wide do you think the wheel would have to be to give a smooth ride? |
#7
Here's a render of the latest revision. It's little bigger (effective diameter of 8ish inches), and uses more machining resources. to shave weight off. Once I hit a revision that i feel comfortable putting on a robot, I'll be hosting the CAD for anyone that wants it, with only one rule: if you make it or modify it, you also have to put the CAD up. It's time to bring Open Source to robotics, folks. ![]() |
#8
can you render it with a viewpoint that's much further away, so the view of the side of the wheel is "flat"?
also....open source is nice! we did some this past season, I know we inspired a few teams |
#9
I'm not understanding this, sorry.You're asking for a view that's in orthographic, not perspective, and from a "front" of the wheel view, or a "side" (front being looking at the narrow view, what I have in the middle there, "side" being the one on the left)?
#10
side view, as in looking at the side of the robot. The view in the left of your picture above. Change the perspective to infinite, so you can see how "round" the wheel is.
#11
Thanks in advance! Brando |
#12
The only question i would ask would be if they were to be bumped into would they break easier or would they still have enough strength.
#13
They're quite solid as they stand, but I don't like leaving a wheel uncovered for any reason. For that reason I'll probably enclose the wheels, most likely in 1/8th aluminum sheet on which the bumpers will be mounted. |
#14
![]() Then you revolve it around that bottom line. After that you put a hole through the center for the bolt, then put recession into the roller for bushings. Last edited by CraigHickman : 23-11-2008 at 22:39. |
| pic: vex mecanum 1 | psyco_klown | Extra Discussion | 9 | 05-05-2008 23:22 |
| Musings from a FIRST Inspector | Wayne Doenges | General Forum | 36 | 26-02-2008 21:31 |
| pic: Mecanum Prototype 1 | Doug G | Extra Discussion | 8 | 06-04-2007 21:34 |
| pic: 1" mecanum | Tytus Gerrish | Extra Discussion | 8 | 04-10-2005 13:44 |
| Sweet Repeat musings........................ | skrussel | Off-Season Events | 3 | 19-10-2003 23:33 |
