Seen in the past...
Posted by Nate Smith at 1/24/2001 11:35 AM EST
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain. In Reply to: Re: No, but you can copy the design Posted by ChrisH on 1/23/2001 1:31 PM EST: : Actually, it may be that you can. If it's a fastener it's on the additional hardware list and is unlimited. As I recall if it holds two or more parts in FIXED relation to one another, it's a fastener. But I'd check with one of the technical reps at FIRST before I based my robot around it. : You'd be suprised what can be a fastener! : Chris Husmann,PE : Team 330 the Beach'Bots : : Will, : : No, you can't legally grab a muffler clamp and modify it to mount your motor. : : But, you can use approved materials (on Additional Hardware List or out of Small Parts, Inc.) to make your own clamps that look just like the muffler clamps. : : Good luck, : : Andy B. I know of at least one machine that used this method of mounting the drill motors in '99... Nate |
